Previous in Forum: Hi   Next in Forum: Actual Bolt Size
Top Gas Recovery Turbine (TRT)
12/09/2014 11:01 PM
To design TRT capacity, how Blast Furnace top gas flow rate (Nm3/hr) shall be estimated ?
Re: Top gas recovery turbine (TRT)
12/09/2014 11:35 PM
Carefully and correctly. Using methods you don't know.
Do not even think about trying to do this yourself.
Re: Top Gas Recovery Turbine (TRT)
12/10/2014 7:12 AM
Instead of asking here, why don't you talk to the Process Engineer on the project instead?
Good moaning!
12/11/2014 10:17 AM
What kind of unit is Nm3/hr? I have never seen that before. Are you referring to m3/hr at "normal" standard conditions? You should probably also be looking at mass flow, since that is what makes the spinny thingy go around. Temperature and pressure are key to understanding that also.
12/14/2014 2:40 AM
Are you qualified to do it. Just leaves it to the designer to do the jobs.
Register to Reply 4 comments
Crabtree (1); James Stewart (1); lyn (1); Simon Wan (1)
