Previous in Forum: Flow Transmitter   Next in Forum: Ultrasonic Level Transmitter for Tunnel, Inside Hollow Pipe
Impulse Purge for Pressure Transmitter
12/11/2014 12:56 AM
We are tapping process line ( Air) to absolute pressure transmitter, but we are getting an impulse purge air line via variable rotometer and joins via Tee union through pressure transmitter. Why impulse purge line is required..??
5
Re: impulse purge for pressure transmitter
12/11/2014 1:14 AM
<Shakes head in disbelief>
Best Practice Guide Impulse Lines for Differential-Pressure ..
Many more good references are available if you could only use a search engine.
Re: Impulse Purge for Pressure Transmitter
12/12/2014 7:49 AM
Normally purge is used if the impulse tube can get plugged by dirty fluid.
The purge fluid must be compatible with the process.
If you don't know where you are going,you are bound to get there
Register to Reply 2 comments
