Previous in Forum: Global Electric Capacity Crisis - Really!   Next in Forum: Operational Navy Laser
10 comments
Thick Glass Fiber Laminate
12/13/2014 2:01 PM
I need to make a glass fiber and vinilester resin disc, 12" diameter, 1.5" inchethickness. I have a mould to do it.
There is a way to make it by hand layup in just one step?. I have requested some info from experienced workers but they say that it should be done in several thin layers, to avoid the excess of heat, delamination and warpage.
I would like to do this by infuson process, so I have experience with that process, but in thin layers.
Re: Thick glass fiber laminate
12/13/2014 2:14 PM
What about making a sandwich?
12/13/2014 2:22 PM
It is a very good idea, and I have done it before with Carbon and Nomex honeycomb, but now I need to make those discs in full glass fiber + Vinilester resins.
12/13/2014 4:13 PM
If the experienced guys say it needs to be done in thin layers...
Would you believe a talking cat if he said just go for it in one thick layer and be damned?
If you ask enough people you'll eventually get the answer you want... it doesn't mean it will be right though.
Experiment, that's the best I can suggest.
12/13/2014 5:54 PM
Look up exothermic reaction.
Chemical crosslinking of vinyl ester resins generates lots of heat.
You might be able to do this by inhibiting the cure speed. Maybe cooling the mold would work, or using less catalyst.
Depends on the physical properties you need.
And why not an epoxy resin?
12/13/2014 6:02 PM
Epoxy resin is not allowed as customer requested that product with chemical resistance to sulphuric acid, where vinylester is second to none.
12/14/2014 12:03 AM
Have not had good results trying to cool the mold. That was with epoxy, but even so.
Engineering Fields - Aerospace Engineering - Aerospace Design Engineer... Popular Science - Weaponology - Aerospace Design Engineer...
12/14/2014 1:09 AM
Take a look at the Wind Blade Manufacturer they do it in one step (using Resin Infusion) and have a compareable thickness if not thicker to your project. But do it in better quality because the wind blade´s lay-up is sometimes horrible.
Try it!
Good Luck
Good Answers: 153
12/14/2014 7:10 AM
Woven fiber glass cloth when compressed in multi-layers is much denser than fiber mat, therefore it uses less resin, and less resin equates to less heat.
Stamp out 50-60 discs of fine weave fiber cloth.
Weigh the empty mould (and compression clamps).
Lay into the mould so that each layer is rotated 45° from the one below until the thickness is 1.5" when compressed to say 500Kgs.
Weigh the mould again, then using the density for solid glass work out the volume of air gaps in the weave. This gives you and exact volume for the amount of resin required.
Pour in the resin, compress to 500Kg/1.5" forcing the resin into the cloth weave and between the layers
Leave to cure.
Tolerances can be very finely controlled using this type of pressure moulding.
12/14/2014 7:54 AM
Use the resin transfer method and do not scrimp on the fibers, the resin is only the bond and has little strength. With a small vacuum pump you can draw the resin in avoid any air pockets minimize the amount of resin and I suggest minimum activator as recommended by manufacturer. Kick off time can be controlled somewhat by temperature of mold and air in process area. Slow activation will dramatically reduce heat from activation and provide stronger part.
Re: Thick Glass Fiber Laminate
12/15/2014 7:11 PM
I have circumstances where there has been a lot of resin left over in my ice cream container/bucket and yes there is heat but not enough to cause a fire.
Jim
Register to Reply 10 comments
badbob (1); Fundacion (2); jhhassociates (1); JIMRAT (1); lyn (1); R0man (1); roy hammy (1); SolarEagle (1); user-deleted-1105 (1)
