Previous in Forum: Spur Gear   Next in Forum: Nitrogen PSA Unit & its Compressor Efficiency
12 comments
Motor Shaft, Pulley and Key Standard MOC as per Design
12/16/2014 11:37 AM
i want to know which type of material used for motor shaft, pulley and key making use.
Pathfinder Tags: devsum
Hobbies - CNC - New Member
Re: motor shaft, pulley and key standard MOC as per design
12/16/2014 11:41 AM
  1. Steel or stainless steel for the motor shaft.
  2. Aluminum for the pulley.
  3. Mild steel for the shaft key.
Next question please!
12/16/2014 11:45 AM
2.pulley can be make cast iron or not ?
3. which Material grade for key....?
please give me answer......
12/16/2014 11:53 AM
It's difficult to specify materials when you give so little information.
Take a few minutes to describe what you are trying to do.
You can make or buy the pulley with any material you want.
Aluminum is light weight, durable and will lower your rotational force.
Key stock is typically 1018 mild steel, however the key can be made from many different materials and the application usually specifies the material. I.E. in a wet environment, maybe all parts will be stainless steel.
Good Answers: 183
12/16/2014 1:33 PM
Keys are standardized and in the norm is the material specified!
You ONLY have to make the effort to ask Google and then you get the answer.
It is not difficult and you do not risk to be told what to do.
12/17/2014 12:19 AM
What is the maximum hp transmitted by aluminium pulley,will it tolerate/withstand rapid start/stop,jerks etc,why they use C.I pulleys?.
pnaban
12/16/2014 11:48 AM
Ask the designer.
Good moaning!
12/16/2014 12:21 PM
It can be a number of materials, machined, cast and cast can be made out of difference materials.
As a designer, Machinery's Hand book can help you out. And for a designer it can be looked at as the bible
Or you can check out McMaster and gleam some information off of that.
keys
Good Answers: 97
Re: Motor Shaft, Pulley and Key Standard MOC as per Design
12/16/2014 2:24 PM
Know to consider eddy's currents when choosing material of shaft of motor.
CRTL-Z
Good Answers: 183
12/16/2014 6:45 PM
Which is the reason ?
12/16/2014 4:00 PM
It could be almost anything, it depends on what you buy or what you make. For example the pulley and/or key could be some polymer or nylon or wood for that matter....
Good Answers: 25
12/17/2014 6:13 AM
Motor Shaft--En 8 or En 9
Pulley- Cast Iron
Key--En8.
12/17/2014 3:44 PM
Briggs and Stranton used to use a soft aluminum key on lawn mower engines so the key would shear and the flywheel would spin if you hit something and too abruptly stopped the blade. So, as you see, there are many possibilities depending on application. What is yours? -- JHF
Register to Reply 12 comments
Circuit Breaker (1); Crabtree (1); devsum (1); Massey (1); nick name (2); Original_Macgyver (2); phoenix911 (1); pnaban (1); suresh sharma (1); Unredundant (1)
