Previous in Forum: Steam Turbine Brush Seals   Next in Forum: Electrical AC/DC Motor Testing
Group Insertions in Battery Industry
01/02/2015 11:49 PM
While inserting the group in to container we are getting problems is there any possibility for vacuum group insertion?
Re: Group insertions in battery industry
01/03/2015 12:26 AM
A vacuum is just the lack of the gas we call air. A vacuum region working with an atmospheric pressure region can produce considerable force with a sufficient area. More force on something that doesn't fit will just more likely break.
More power can just mean more mess to clean up.
01/03/2015 3:25 AM
1. Get a bigger container.
2. Get a smaller group.
Good Answers: 140
Re: Group Insertions in Battery Industry
01/03/2015 2:30 PM
It is clear that your Internet provider charges you by the word entered. If you want any sort of real answer... give us the details, all of them. People here hate playing 20 questions to get all of the info needed to make a valid comment! To many posters love to play 20 questions and it is right pain in the...
01/07/2015 5:35 AM
Your basic problem is, plate group is more than the slot it should go in. It could be by wrong design or improper thickness control while making plates. Almost 1/3 rd should go in freely and then balance be inserted with gentle push by hand or machine arm, in between the taper side walls of plastic container. By Vacuum it is not done , as there is no access and top is open. You may also try by covering the group with thin plastic sheet and then insert the group. It will reduce the friction of end negative plates. Too tight boxing will impair the performance of the plates.
Register to Reply 4 comments
lyn (1); North of 60 (1); ranabir chakraborty (1); redfred (1)
