Previous in Forum: Orifice Calculater Software   Next in Forum: Inalambric Strain Gauges
Centering the Data
01/07/2015 11:58 AM
Hi, I need to the various ways of centering the data.I have a data in which first portion is non centered.I want it to be centered around zero without changing the values of data.My data is oscillating with peaks.
One method I thought is to subtract the mean for every portion between peaks and then add the mean while reconstructing back for every portion of the data.please help me with suggestions.
Re: Centering the Data
01/07/2015 12:17 PM
If you can't change the values of the data, you can't do much.
If you want it centered around zero, subtract the mean from all data points. This will leave the relative values the same (difference, not ratio).
Re: centering the data
01/07/2015 12:22 PM
Taking the mean and removing the offset is the standard method of centering your data. This may not tell you what you want to know so a different analysis technique maybe warranted. Another analysis technique you should consider is taking a Fourier Transform of your data. You could calculate the standard deviation and perform a random process analysis to determine what random process is in your data. You could perform a least squares fit to see to a linear, exponential or other curve to analyze your data. A deviation from each type of fitted curve can identify if with a random process analysis can also be performed. A myriad of other regression analysis techniques are available that can reveal a hidden trend or attribute of your data.
United States - US - Statue of Liberty - How's it going?
01/09/2015 12:06 AM
I like to use deviation from the mean for some of my analysis.
http://en.wikipedia.org/wiki/Standard_deviation
If you can't explain it simply, you don't understand it well enough. AE
Register to Reply 3 comments
nvirciglio (1); redfred (1); Rixter (1)
