Previous in Forum: WRC 107/297 Local Shell Thickness Consideration   Next in Forum: Weld Joint Strength Reduction Factor (W) in ASME B31.3
3D Kinematics - Angular Velocity
01/08/2015 5:52 AM
Hey folks,
I got a question about 3D kinematics.
Dynamics book by Kane & Levinson says:...
Let b1, b2, b3 form a right handed set of mutually perpendicular unit vectors fixed in a rigid body B moving in a reference frame A. The angular velocity of B in A is defined as
Angular Velocity ~= (b1)(b2dot)[dot product](b3) + (b2)(b3dot)[dot product](b1) + (b3)(b1dot)[dot product](b2)
Do you guys have any idea of how it can be derived like above ?
Confused on the definition... it is quite abstract...
Re: 3D kinematics - angular velocity
01/08/2015 6:36 AM
r = [b1 b2 b3] is the displacement of the object B from the origin in A
v = [b1dot b2dot b3dot] is the velocity of object B in A
Angular velocity ω = (r X v)/|r|2 where "X" is the vector cross product
Good Answers: 137
Re: 3D Kinematics - Angular Velocity
01/08/2015 8:10 AM
I'm a bit rusty on vectors, but trying to compare your formula with Rixter's. As b1 etc are unit vectors |r|2 = 1, which simplifies things a little.
Can you explain what (b1)(b2dot)[dot product]b3 means? The dot product of vectors b and bdot
b.bdot = b1.b1dot + b2.b2dot + b3.b3dot if it's any help.
Cross product
b X bdot = (b2.b3dot - b3.b2dot),(b3.b1dot - b1.b3dot),(b1.b2dot - b2.b1dot). Doesn't seem to agree, but I don't suppose Kane & Levinson would get it wrong!
01/08/2015 12:47 PM
"Angular Velocity ~= (b1)(b2dot)[dot product](b3) + (b2)(b3dot)[dot product](b1) + (b3)(b1dot)[dot product](b2)"
There sure seems to be an error. Dot product implies two vectors and returns a scalar value. The dot product of two perpendicular vectors is zero. I don't see how to interpret any of the terms above as not the dot product of two perpendicular vectors. It would be good to see this in context.
01/08/2015 1:08 PM
I believe "[dot product]" should be "[cross product]".
01/08/2015 12:46 PM
Definitions are given, not derived.
Codemaster (1); Rixter (3); Tornado (1)
