Previous in Forum: Toy Motor to Convert Generator   Next in Forum: Philippines 220V-60hz vs Europe 230V-50hz
Paralleling of 66KV Line
01/08/2015 8:52 AM
One line comming from 220/66kv Subsation and Other comming from 132/66kv Sustation both parelleling done at 66kvsubstation when the single line is in service total load is 158Amp after paralleling with the other line the the load bifurcation is 136.64Amp and 60.17Amp = 196Amp which is more than the actual load whats the cause affected
Before parallel data:66.61kv,158.06A,17.02MW,0.95 P.F.,
After parallel data:
Line:1 from220/66kv SS : 66.5kv,136.64A,12.04MW,0.78 P.F.,
Line:2 from132/66kv SS : 66.5kv,60.17A,4.90MW, -0.74 P.F.(-ve),
Re: Paralleling of 66KV Line
01/08/2015 9:18 AM
Still sounds like a homework problem.
01/08/2015 1:03 PM
You have asked this question before. The answer is the same.
http://cr4.globalspec.com/thread/98944/Paralleling-of-66KV-Lines
01/08/2015 1:14 PM
There is one little addition from before. This time the power factor numbers are included. I'll give the OP a big hint on this homework problem. The sign of the power factor means what?
Good Answers: 444
01/09/2015 11:03 AM
"...whats the cause affected...", a lack of understanding of basic electrical power math. You cannot use algebra to add vector quantities, you must know both the magnitude and the phase angle of the quantities involved (phase amps here); i.e., 136A + 60A does not equal 196A unless they are in phase, otherwise your answer is always wrong.
Go back to a basic AC Circuits textbook to learn more.
Good Answers: 22
01/11/2015 12:43 AM
Jagdish Rathod,
Load seems to be approximately same, looking at the kW figures. Currents indicate that there is VAR flow from 132/66kV substation to 220/66kV substation via your 66kV bus.
Raghunath
raghun (1); RAMConsult (1); redfred (2); wareagle (1)
