Previous in Forum: Query Regarding Atlas Copco VSD Air Compressor GA37VSD   Next in Forum: Marine Diesel Engine Daihatsu DK Series
11 comments
Atlas Copco Air Compressor VSD30 Issue
01/13/2015 8:12 AM
I have purchase Atlas-Copco VSD30 air compressor three months before . It has inbuilt air dryer. since from commissioning the dryer PDP temperature is 7 to 8 deg. It is not coming down even at 45% load. I'm in touch Atlas-copco team but they are not responding well. Air dryer all parameter are okay. what could be the reason fro dryer PDP temp high.
Good Answers: 11
Re: Atlas Copco Air Compressor VSD30 Issue
01/13/2015 8:52 AM
Is the unit air cooled or water cooled?
01/13/2015 8:58 AM
it is refrigeration air dryer " air cooled "
Good Answers: 11
01/13/2015 9:47 AM
This is what you mean right?
If there something hot, then there is a source.
Typically not air cooled.
You must trace along the path of no return--
01/13/2015 10:06 AM
What PDP did you expect ?
Do you have a refrigerant type dryer or a dessicant type ?
Did you purchase a new system or a used system ?
If you purchased a used system with a dessicant dryer, did you replace the media prior to use ?
Why did you expect the PDP to vary with compressor load ?
Please answer some of these questions instead of ignoring them....
Anonymous Poster #2
01/13/2015 10:16 AM
hmmm...I knew you by the voice in my ears, definitely.
01/13/2015 10:52 AM
PDP I want is 2 deg. C, yes dryer is refrigerant type. it is new system. not expecting to very PDP on compressor load, but even 40% load it is giving desired PDP. as load increase PDP reached @ 10 to 12 deg c
Good Answers: 11
01/13/2015 11:06 AM
2 deg C, its almost freezing at atmospheric pressure, what the heck do you want to have it that way?Does the manual tells you so?
Water in air when pressurized increases boiling point temperature. Therefore, @ 10~12 deg C, its already condensed far more, may be solid to some extent. -- Are you kidding me?
01/17/2015 12:24 AM
I AM NOT KIDDING MR. NOUDGE.
we are getting 2/3 deg temp at adjutant compressor. i.e. for moisture free air.
Good Answers: 104
01/13/2015 4:10 PM
What is AC's design PDP? It is commonly about 3 - 4 degC. What refrigerant does the system use and what is the evaporator pressure?
01/14/2015 9:15 AM
How are you measuring the dewpoint?
By thermometer at the lowest temperature of the air inside the pipe.
By contact thermometer on the outside of the pipe.
By suction pressure gauge gauge.
By sample of outlet air using hygrometer.
Engineering Fields - Chemical Engineering - New Member
01/16/2015 9:51 AM
Have you checked temperature of cooling water supply to coolers, I mean in terms of flowrate & temperature. In our process industry single cooling tower give supply to many hydronic systems, so when we utilise it at many places simultaneously flowrate suffers...
Chemical Engineers are like high Temperatures & high Pressures
Register to Reply 11 comments
Anonymous Poster (2); bigg (1); horace40 (1); nightcrawler (1); Noudge79 (3); pradipp (3)
