Previous in Forum: Atlas Copco Air Compressor VSD30 Issue   Next in Forum: Does Torque Drop?
12 comments
Marine Diesel Engine Daihatsu DK Series
01/13/2015 1:09 PM
We encountered problem to our diesel engine generator. Cylinder # 5 low exh. temperature and pmax. We changed already the cylider heAd,fuel enjection pump, nozzle for fuel atomizer,and piston rings, but the problem still exist. what are the other possible cause of this problem so that we could rectify it..thanks for your help...
Re: Marine Diesel Engine Daihatsu DK Series
01/13/2015 3:55 PM
Could be a bad wire or plug.....what's pmax? and heAd? could be a problem with the valve or assy...
01/13/2015 4:01 PM
Oh, come on.
LynDoor™Industries Transomatic is always running in the background.
Just press CTL/ALT/trans/F4\WTF/jjm-pp.
cylider haEd= cylinder head.
01/13/2015 8:13 PM
I can't my pmax is stuck....
01/13/2015 9:51 PM
In your assy?
01/14/2015 2:10 AM
Bacon bacon bacon...
01/13/2015 3:57 PM
One possibility is a failure to pick up the phone and talk to Daihatsu directly beforehand. Eliminate that one, will you, please?
Good moaning!
01/13/2015 4:02 PM
Using the phone is, apparently a sign of weakness.
Power comes from having others do your bidding work for you.
01/13/2015 5:42 PM
Tune up valve timing
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
01/13/2015 6:46 PM
Good day efrnpaluca,
Did visual inspection of the parts removed reveal any tell tale anomalies such as: excessive carbon deposits from incomplete combustion, wear on piston rings, does the cylinder wall shows abnormal wear pattern, etc.
Good Answers: 109
01/13/2015 10:29 PM
Why would it? It was changed out because they can!
01/21/2015 5:45 PM
Did you ever find out what caused the problem?
Register to Reply 12 comments
Crabtree (1); Gannet (2); IdeaSmith (1); Kulas (1); lyn (4); SolarEagle (3)
