Previous in Forum: Serial to Serial Converter.   Next in Forum: Transformer
Power Consumed by Online UPS
01/13/2015 9:58 AM
Good evening all, I have 500 kva, 11 kv/433 volt transformer and a 30 kva, 3 phase 440 volt input, 3 phase output and consisting of 12 volt, 160 AH, 20 Nos battery set online ups. Every month we are paying approximately 20 lac to utility. When we connected this ups for emergency lighting to the system our energy consumption increased almost by 30 % even utility power never interrupted When we disconnected this ups from the system again the bill amount dropped to regular i.e 20 lac. My query is does this ups consumes extra power even when power is available from utility?.
Good Answers: 11
Re: POWER CONSUMED BY ONLINE UPS
01/13/2015 10:14 AM
Could be from charging the batteries. When battery saturates(fully charged), some charges created heat instead.
By the analogy of batteries the same to air reservoir or tank, compression always results to heat up - so does fully charged battery when online(unplugged)..
Re: Power Consumed by Online UPS
01/13/2015 11:18 AM
Yes they do, depending on what type of UPS you have the energy usage can vary....I would check with the manufacturer rep to see if yours is operating to spec, and see if any improvements can be made....or you could read the manual....
01/13/2015 3:47 PM
Yes. Nothing in life is free.
Good Answers: 49
01/13/2015 11:46 PM
As noted earlier- UPS systems always draw more power than they serve.
Your best choice is to disconnect the INPUT power to the UPS during daytime (periods of high power demand) and back on during nighttime (when power rates are lower and no demand charges in place).
The batteries will always be there for back-up supply (although possibly at a slightly lower ride-through time, depending on how long since input power was cut) but the impact will be minimal.
Getting that parasitic load OFF the prime, On-Peak time slot will very likely save you a significant amount of money with VERY little risk.
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
01/13/2015 11:54 PM
Or,
put a cheap timer in the supply circuit.
energygod (1); lyn (2); Noudge79 (1); SolarEagle (1)
