Hi Everyone .. Sir we use Mitsubishi 3.5kw vfd which is connected to a sew motor and this motors operates based on brake actuation of same make sew .Problem faced is when motor runs in fwd direction current drawn is around 1.5A but in reverse direction it's drawing around 4.5 A as per inverse time characteristics it runs for few seconds and get tripped with O/L fault indication. suspected mechanical obstacles during the movement but nothing found and also its bearing replacement done so then changed the motor along with gearbox also But still problem persisting and at last suspected on malfunction of vfd and changed the same with brand new one. It was running successfully from past 1 day suddenly even this vfd is showing the same as before during forward movement 1.5A and for reverse 4.5A ..... Please suggest me does vfd malfunctions if yes then wat might be the abnormalities that we can locate
