Dear All,
Please help me to decide drain outlet temp. of Gland Steam Condenser for following parameters:
Shell side Medium & Flow : Steam-75.6 Kg/hr/Air- 43.2 Kg/hr
Pressure to be maintained in GSC : 0.95 Kg/cm2 abs
Inlet Steam Temperature to GSC : 250 deg.C
Drain Outlet Temp. = ?
Cooling water / DM Water : Condensate from CEP
Quantity : 86.01 TPH
Inlet Water Temperature : 46.63 deg.C
Outlet Water Temperature ?
Water Pressure : 12 Kg/cm²
Heat load?
Volume Flow, Fan, m3/s ?
Kindly help me to solve this problem.
Regards,
RAKESH SONI
