Previous in Forum: Help on Transformer Test   Next in Forum: About AC Electric-Magnetic Simulation
18 comments
Good Answers: 94
Force to Compress Adhesive Bond
02/10/2015 6:11 PM
We need to connect an array of pads on a PCB to the same array on a ceramic anode & one method we are considering is to use conductive epoxy. We're starting with the easy one, roughly 0.7mm square pads on a 1mm pitch in a 32x32 array. Eventually we need to do 0.3mm square pads on an 0.4mm pitch in a 128x128 array. The plan is to squeegee the epoxy through a metal mask on to one of the parts then apply the other.
Obviously we don't want the epoxy to squidge out so much that the pads short out to each other so my question is:- is it possible to calculate how much pressure is required to compress the joint to a given thickness given that we would know the volume of adhesive, the area of the pads & the viscosity of the epoxy.
Re: Force to compress adhesive bond.
02/10/2015 6:26 PM
Your title is misleading.
Do you want to compress the mask, the squeegee or the part after placement.
This is done every day in high volume production. The mask is just large enough to clear the pads. So hole location and tolerance is important. Consistent pressure is required. No bowing allowed.
First, the parts do not need any compression during bonding.
The metal mask is applied to the surface of the board and the squeegee pressure and speed is the key.
Depending on the quantity of boards to process hand squeegeeing may be the way to go. A light touch and plenty of adhesive ahead of the squeege is the best approach.
Trial and error is the best guide.
The process can be automated, if the quantity allows.
Here's a couple of sites.
Remember, there's always enough time to remove the adhesive and do it over if you get too much paste on the pads. It won't take much.
Solder Paste Stenciling - SparkFun Electronics
PCB Solder Stencils - Sunstone Circuits
Good Answers: 94
02/11/2015 5:26 PM
We want to compress the PCB on to the anode after applying the epoxy. The intention is to ensure that we get a good connection but excess pressure might cause the epoxy to spread too far & short to the adjacent pad.
We had in mind a stencil similar to those used for PCBs & hand squeegeeing the epoxy.
These will be very much 1-offs until we prove the whole device & thereafter, a few hundred devices.
02/12/2015 5:41 AM
Since you are in uncharted territory, consider this. Include glass or metal microspheres/beads in the solder paste. This may require special processing to mix in the beads, but will limit the amount of squeeze-out of the paste by controlling the amount of compression of the joint.
While I have used this method with adhesives bonding, I have never done it with solder paste.
Good Answers: 94
02/12/2015 5:48 AM
That's a good thought, I've seen that in other adhesives to control the bond thickness. There might be some concern about the beads reducing the contact area of the pads as they are so small but I guess the beads could be quite widely dispersed. What we are considering is not a solder paste, it is a conductive adhesive.
02/12/2015 5:59 AM
Sorry, conductive adhesive. I knew that. This might still work, since conductivity does not rely on continual pressure, once the resin has cured.
Just a thought.
Good Answers: 94
02/12/2015 6:12 AM
That's right, no pressure required once it has cured but the electrical resistance of the joint will depend on how many conductive particles contact the 2 surfaces. Introducing spacer beads might compromise this. At the moment I'm not sure what the optimum joint thickness would be.
02/12/2015 8:50 AM
Good Answers: 94
02/12/2015 9:00 AM
That's interesting, having a predetermined joint thickness would allow us to predict the spread of the epoxy without detracting from the conductivity.
Re: Force to Compress Adhesive Bond
02/10/2015 10:57 PM
Yes the question is how many ?
http://www.google.com.ar/patents/US5410806
02/10/2015 11:15 PM
Sorry, the worst possible example to give is a patent.
Patents are written to be unusable by those not "well schooled in the art."
OP would be better served by visiting a silk screening shop nearby and seeing how T shirts are decorated, or signs are printed.
02/11/2015 12:13 PM
Seemed clear enough to me....
02/11/2015 1:11 AM
Trial and error method is the best. You could estimate however the volume of adhesive (LxW of panel)xH, (you could minimize this) of adhesive. Pressure does not guarantee that epoxy will be distributed well on the surface. There should be a means of applying the epoxy evenly on the pad. Pressure would be a little help for the pressing the pads even on the whole area.
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 94
02/11/2015 5:30 PM
We can estimate the volume of epoxy & try to control this by way of the hole size and thickness of the stencil used. I agree that pressure will not necessarily be even but we still feel that pressure will be required to get a good connection.
02/11/2015 6:25 AM
Have you considered a Z axis connector? You often find them in calculators to connect the display to the PCB.
https://www.google.co.uk/search?q=Z+axis+connector&ie=utf-8&oe=utf-8&gws_rd=cr&ei=OzvbVKmmH-a07ga8jIHYBA
Good Answers: 94
02/11/2015 5:37 PM
This would work if we had a single row of pads to connect but not with a square array of pads.
We are also looking at using ACF sheets which contain conductive particles & work in a similar way to the Z connectors. I'm currently building a jig to test the application of the ACF.
Good Answers: 97
02/11/2015 12:45 PM
CRTL-Z
Good Answers: 94
02/11/2015 5:39 PM
We've taken advice from various manufacturers about suitable adhesives but, as usual, our situation is one that they have not encountered before.
Good Answers: 94
02/21/2015 7:35 PM
We will be trialing some conductive epoxy with the conductive microspheres & I will report back on how this works. We will also be trying the ACF film to see which is best.
Register to Reply 18 comments
Kulas (1); lyn (5); Nigh (8); Randall (1); SolarEagle (2); Unredundant (1)
