Previous in Forum: ATS   Next in Forum: Cables in Conduit
Air Compressure Coil
02/13/2015 6:08 AM
Hello, my air compressor,motor is stat in star delta startor. Delta Contactor coil burnt with in one hour this problem is repeating three times. Motor of the compressor is 90kw & contactor is using 3TH50 Siemens make & coil voltage 220VAC. So please suggest that how to protect contactor coil.
Good Answers: 444
Re: Air Compressure Coil
02/13/2015 7:41 AM
Best way is to find out why the coil is burning out before you burn out yet another one. Check the voltage and current, unless you are using inferior contactors coils just don't burn out for no reason, find out what it is.
02/13/2015 8:35 AM
According to your description,.. I think there's some undervoltage in the source feeding the contactor's coil in question, which will -in turn - result in overcurrent in the coil(definitely, it'll burn out over time). Also, this can happen because of the accumulation of dust all over the contacts and terminals of the contactor, so clean it inside out.
I hope this helps.
Just live and .. Learn!!
Good Answers: 22
02/14/2015 9:04 AM
Apparently, the delta contactor coil is getting higher voltage than rated (220V), it could be 400V (Ph-ph voltage instead of ph-E voltage??).
Please check the circuit and it should be clear.
On second thought, if the LV system is rated 415V, the corresponding phase to earth voltage will be 240V and assuming that the upstream source transformer is not loaded fully, the actual 415V bus voltage is likely to be ~430V which means the Ph-E voltage of ~250V. If the delta contactor coil is rated 220V and not 240V, can this over voltage be the reason for the coil burnout??
Raghunath
Register to Reply 3 comments
Ali18 (1); raghun (1); RAMConsult (1)
