Previous in Forum: What is the Most Important Logic Gate?   Next in Forum: Probability
Danfoss VFD Selection
02/16/2015 7:03 AM
please discribe the main diffrence between danfoss VLT automation drive, VLT AQUA Drive and VLT HVAC drive, and what is selection procedure.
with best regards
Re: danfoss vfd selection
02/16/2015 9:06 AM
Different names, brands, prices and features.
A thorough literature evaluation by a qualified engineer, followed by demonstrations of the products by a tech rep, followed by an informed decision by a that engineer.
In other words, if you have to ask, get competent help, this job is too much for you.
02/16/2015 9:52 AM
they all are danfoss brand, just want to know main difference, how can we describes their selection for usage.
with best regards
02/16/2015 12:59 PM
Simple."We" pick up "our" telephone, and "we" talk to Danfoss directly.
Good moaning!
Good Answers: 804
02/16/2015 12:31 PM
One is for water projects, one is for HVAC projects. The only differences are in the pre-loaded application profiles. So the Water version will not have application profiles geared toward fans, and the HVAC version will only have water based application profiles geared toward HVAC equipment such as cooling towers and circulating pumps. Other than that, they are exactly the same.
Good Answers: 117
Re: Danfoss VFD Selection
02/17/2015 12:22 AM
None really.. a VFD, Variable Frequency Drive, in a basic form is just that a device that varies the frequency output to a motor to control the motor RPM. (you understand the basics of a VFD yes?)
Together Danfoss, and ONLY you as the engineer (you are the engineer in charge yes?) will be able to determine by reading the tech info (as suggested) or calling the local rep (as suggested) (they have a Danfoss distribution rep in Pakistan?) to decide which one is suitable fro your need.
brich (1); Crabtree (1); JRaef (1); lyn (1); rao73 (1)
