Previous in Forum: Cat Generators   Next in Forum: KEWANEE Boiler Relay
10 comments
Device 87 Operation
02/20/2015 4:46 AM
Fellow engineers, please what will be some of the contributing factors that will cause a defferential relay ( device 87) to operate any time trying to close the breaker. But after continues trying for about 4 times, the breaker then closes and the votage regulator transformer stays.
Good Answers: 73
Re: Device 87 operation
02/20/2015 8:48 AM
Perhaps it is designed to do that?
02/20/2015 8:55 AM
02/20/2015 9:13 AM
ESO
Good Answers: 122
Re: Device 87 Operation
02/20/2015 10:23 AM
The electrical difference(s) between phases is outside the existing relay protection parameters.
It is important that you identify which element is not in compliance.
Frequency? Phase angle? Voltage level?
I strongly suggest you have a protection system engineer analyze the circuit and relay settings before you attempt another breaker closure.
If you close the breaker and there is too much difference between the systems the breaker can fail causing severe damage and/or personal injury.
02/21/2015 6:06 PM
Thank you all.But my worry,why does the breaker closes any time after serviral attermt. device 87 operates on first and second,then closes
02/20/2015 10:29 AM
Where can I get a deferential relay for my wife?
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
02/20/2015 10:33 AM
Would she use it?
02/20/2015 11:31 AM
Too bad, i work on device 88 & 86=]
Cheer, Stu.
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 445
02/20/2015 6:27 PM
The most likely cause will be installation, commissioning, and testing by someone who does not know how to do all of the above. Your 87 relay operates because the CTs are sensing an imbalance in the current entering and leaving their zone of protection. Usually this indicates a faulty component, but in your case I suspect that no one checked the polarity of the CTs and their wiring from the devices to the relay. Get someone knowledgeable out there before you actually cause an expensive failure.
Good Answers: 22
02/21/2015 11:29 AM
Transformer differential protection you are talking about, if my understanding is right.
The transformer differential protections are known to trip during transformer energisation if 2nd harmonic detection (with appropriate threshold and duration set) and protection block is not enabled.
There are other settings also that are important to make sure that the protection is stable during transformer energisation as well as during normal working that follows.
Review the settings critically with the recommendations given in the relay technical manual. That should help alleviate the problem.
By the way, repeated energisation of transformer when there is differential trip is not an acceptable operating practice in the industry. It could be serious with fatal consequences.
Raghunath
Register to Reply 10 comments
Kilowatt0 (1); Kulas (1); KWASI BIMPONG (1); Mike W (1); NotUrOrdinaryJoe (1); raghun (1); RAMConsult (1); redfred (2); SHOCKHISCAN (1)
