Previous in Forum: Question About Flow Switches   Next in Forum: Price for Magnetic Sand
11 comments
Boiling Temp of ETO @ .865 bar
02/25/2015 7:30 AM
Hi, Can anyone help this poor MD to figure out the boiling temperature of Ethylene Oxide at a pressure of .865 bar ? At one Bar boiling point is 10.7ºC. Vaporization enthalpy is 25.5 Kj/mol
Pathfinder Tags: ETO´s boiling point
Re: Boiling Temp of ETO @ .865 bar
02/25/2015 9:52 AM
Here's a plot of vapor pressure vs temperature C. 0.865 bar = 648 mmhg.http://www.unit-conversion.info/pressure.html
Vapor Pressure of Ethylene Oxide
02/25/2015 10:21 AM
I think the above plot is incorrect. This plot agrees with your numbers. Sorry, I grabbed the wrong plot.
02/25/2015 12:07 PM
Thanks Rixter! I must confess I went the complicated way, wanting to figure the value out using a complicated (to me) mathematical formula.... forgetting to do the more obvious like searching for a graph, as you did
02/26/2015 10:36 AM
The formula for vapor pressure is usually a simple exponential, wherein the energy barrier used is the heat of vaporization.
For transitions between a gas and a condensed phase with the approximations described above, the expression may be rewritten as
from the wikipedia article on the Clausius-Clapeyron relations (equations). In the above formula, R is the ideal gas constant, with the units is KJ/mole (or Kcal if L is Kcal), L is the latent heat of vaporization, T is absolute temperature (Kelvin degrees), and c is the logarithmic offset (normally called a scale factor to the exponential. This is accurate to first-order approximation, and the link included below has a more elaborate formula where the curvature of the coexistence line (second derivative) is included in considerations. Rixter already gave you a good enough answer though.
Ethylene oxide is nothing to be playing with at any pressure. Are you the Industrial Hygienist at your location? Are you dealing with a spill or a leak? I hope you and everyone else is able to stay upwind of this, and there are no civilians downwind.
02/26/2015 3:44 PM
Here's another form of the Clausius-Clapeyron Equation:
I plugged in the following values:
P1 = 1 bar
T1 = 283.86 °K
P2 = 0.865 Bar
ΔHv = 25.5 Kj/gmole
R = .0083145 Kj/gmole-°K
If I didn't make any errors... T2 = 280.1°K (= 6.9°C)
There are 10 kinds of people in the world.... Those who use binary code, and those who don't.
02/27/2015 6:25 AM
Thank you a lot ! We have applied the same equation, arriving to the same results.
02/26/2015 4:12 PM
I guess you already know that ETO is highly, highly toxic.
02/26/2015 6:43 PM
Not only toxic.... but also explosive! :-)
02/26/2015 9:12 PM
Hmmm.
One cannot help but wonder what your endevour is.
03/02/2015 8:37 AM
My guess is this MD is somehow responsible for attempting to kill very dangerous pathogens with ethylene oxide. My question is this: Is there anything worse you could try such as Polonium 210, or another alpha emitter that would make the place uninhabitable for a longer period of time than ethylene oxide. How do you propose to get rid of the EO? Are you going to use high intensity UV light - be warned that inducing free radicals in this will make it explode, IMHO.
03/02/2015 9:17 AM
Hello James Stewart, thank you for your concern and wise opinion!
Register to Reply 11 comments
James Stewart (2); r&ddoc (4); Rixter (2); tribefan1952 (1); zzorb (2)
