Previous in Forum: Test on 1 phase transformer   Next in Forum: UPS ONGUARD AND ACS BRAND (SAI OR NO BREAK)
Electrical Current Density?
07/10/2007 12:27 PM
define electrical current density.
The Engineer
Good Answers: 129
Re: Electrical Current Density?
07/10/2007 2:09 PM
Current density is the amount of current divided by the cross section perpendicular to the direction of the current. A wire is basically a long cylinder that conducts current. A cross section of a wire is circle. So the current density of a wire is the current divided by the cross section area.
J = I/A
By the way, I find it helpful to check the units of a quantity to better understand it. Current Density J has units Amps/m2.
07/14/2007 7:36 AM
Yes. The definition is right but the unit normally taken is amperes per square cms. Usually for all enclosed busbars its safe and economical value is between 96 & 128 A/sq.cm.
The Engineer
Good Answers: 129
07/14/2007 9:40 AM
I gave the standard SI unit. I'm sure there are many other units such as:
mA/cm2
μA/cm2
A/cm2
etc.
