Previous in Forum: Adverse health effect of exposure to electric and magnetic fields   Next in Forum: Electrical Current Density?
Test on 1 phase transformer
07/10/2007 11:22 AM
If I energized the secondary side of a 1 phase transformer at the time of open ckt test instead of primary,and left open what will happen?Can I get the same result when energized from primary.
Re: Test on 1 phase transformer
07/11/2007 6:58 AM
Of course you will.
The primary and secondary windings are usually interchangable names...
To get more output from a sig gen at low frequencies I've quite often just dug out a small mains transformer and put the sig gen into the secondary to get a couple of hudred volts on the primary.
John.
India - Member - Electrical Energy
07/11/2007 9:35 AM
The results will be the same if the Transformer is 1:1 ratio.Otherwise it depands upon the turns ratio of Transformer.
07/11/2007 12:27 PM
No problem but.....
be sure that when you energize the secondary that you observe the rated voltage and current rating's for that winding.
Snakers
07/11/2007 8:36 PM
both side the winding coil rating same you get the same value both end.
07/11/2007 9:23 PM
Read all the comments by subscribers of the discussion collectively
Anonymous Poster (1); Electroman (1); G.Swaminathan (1); Haajee (1); Snakers (1)
