Previous in Forum: Solution To A Supply Chain Case Study   Next in Forum: Chevy Cavalier Crank No Start
21 comments
Advantages AIRBUS 380
03/04/2015 7:10 PM
This is the new version of Airbus, that has the advantages:
  • superior aerodynamics
  • fuel efficient energy
  • the lowest cost per seat
  • spaciousness for all
  • the widest economy class seats
  • higher capacity to relieve congestion
  • the quietest wide body aircraft
  • outstanding service
  • all operators delighted
  • reducing carbon dioxide emissions
Re: Advantages AIRBUS 380
03/04/2015 7:14 PM
Ok you've sold me on it, can you do better than the $428,000,000 sticker price. CR4 discount?
03/04/2015 7:21 PM
I have a gently flown 2014 model I can let you have for a real bargain....just $32.5m
Will that be cash?
http://www.globalplanesearch.com/pax/jets/airliners/airbus/a380.htm
03/04/2015 7:27 PM
Not with Tan thanks. No pic, no history, ludicrously low price, 51 days listed and no takers.
If something looks too good to be true.......
Good Answers: 123
03/05/2015 2:10 AM
Oh you have it wrong. This fine plane was flown only by a little old lady that only used it for church on Sundays. The only reason that she sold it was because the kids forced her into a retirement home, and it was too big for the parking lot. If I speak to the finance manager, I can probably get you the extended warranty on the powertrain and a new set of whitewalls. if your credit score is up there.
Bob
03/04/2015 7:24 PM
I'd like a test flight.
PHX and AZA can both handle the A 380.
I'm available any time for this.
03/04/2015 8:50 PM
Lyn, drop into either PWM or BGR and pick me up!
03/04/2015 9:31 PM
PMW runways are a little short.
BGR looks OK.
I'll call ahead when we're on our way.
03/04/2015 8:02 PM
1992
Airbus A380
US$ 6,250,000SingaporeAeroController
Classic Planes? Didn't know the 380 was flying in '92.
03/04/2015 8:24 PM
Itsa 320...
03/04/2015 8:29 PM
No, Itsa pauling! The quality of the posts on that aviation site no less.
I dread to think the quality of the threads on the aviation equivalent of CR4.
03/04/2015 9:37 PM
My plane was running fine before washing, now it won't start.....what could be the problem?....also would like to know if it's ok to replace wire control with high tensile rope of same size?.....also how many landings should tires be good for? Please hurry with answer as I have a flight scheduled shortly....thanks
03/04/2015 11:19 PM
Often times they won't start because of issues with the theft deterrent system or crank position sensor or stalls in the rain or fuel pump wiring. Sometimes hitting the tank with your fist will fix it.
03/04/2015 11:57 PM
Hey, started right up....thanks
03/05/2015 1:17 PM
I like the paint job. Just my speed.
Good Answers: 123
03/05/2015 2:19 AM
The tensile strength of the rope is not as important as the conductivity of the rope.
The amount of landings you get on tires depends on where you land. Thin tires are fine for water landings.
Bob
03/05/2015 3:51 AM
Dear Mr.ZakiriaSalim10,
1. What is the Fuel Consumption at full capacity.? Provide some data for Fuel Efficiency.
2. What is the Thrust developed. ? How much Reverse Thrust is developed to reduce the speed from touch down point and before applying brake.
Still some more questions. ?
DHAYANANDHAN.S
Good Answers: 70
03/09/2015 10:30 PM
Hum, didn't know Airbus was into spamming
Good Answers: 123
03/09/2015 10:32 PM
Is that like twerking?
Bob
Good Answers: 70
03/09/2015 10:37 PM
Yup, at least it's not an Anon!
03/11/2015 2:26 AM
Blast! I looked on eBay and I couldn't find one.
Dear CR4. I have an Airbus 380 that cranks but won't start. Should I trade it in for a Chevy Cavalier?
Good moaning!
Good Answers: 123
03/12/2015 12:33 AM
It only needs Fuel, Spark, Compression, and Air.
Start with the easy one. Remove the air filter. Now it will have air.
Next, check for spark. Remove a spark plug wire from the easiest spark plug to reach. Use the spark plug from anything else you have handy, and attach it to the plug wire. Lay that spark pug on something metal under the hood, and have an assistant try to start the car. You should be able to see a bright bluish-white spark at the tip of the plug. If you do continue below. If not, stop and let us know.
If you have spark, reconnect the spark plug wire, and pour about one ounce of gasoline into the air inlet. You may need to squirt it past the throttle valve with a small hole in an old soda bottle. (or similar bottle) If it starts, and then dies, it has no fuel getting to the cylinders. If it does not start, we need to check further, but, this should get you started to finding out what is wrong. Good luck.
Bob
Register to Reply 21 comments
bob c (4); Brave Sir Robin (2); Crabtree (1); dhayanandhan (1); dj95401 (2); jack of all trades (3); lyn (3); SolarEagle (4); Tom_Consulting (1)
