Previous in Forum: Need Suggestions for Selection of Best Topics in Electronics and Communication Domain For Technical Paper Presentation   Next in Forum: 90 Degrees Phase Shift for Input Signal
11 comments
Working FM Transmitter Circuit
03/04/2015 10:03 PM
I tried many fm transmitter circuits which showed zero results. Please provide some working FM TRANSMITTER circuits
Success is a wall made by bricks called failures.
Pathfinder Tags: FM radio transmitter
Re: Working FM TRANSMITTER circuit.
03/04/2015 10:10 PM
Do your own homework.
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
You are becoming a pain in the butt.
Learn how to use a search engine.
03/04/2015 10:25 PM
What frequency are we talking about, standard commercial radio band perhaps?
Was it the circuits that were wrong or did you construct them wrong?
Have you tried fault finding them?
03/04/2015 10:48 PM
Buy one! They will work. Don't expect them to receive AM helps too.
03/04/2015 10:59 PM
http://www.analog.com/media/en/technical-documentation/application-notes/AN-543S.dsp
Since this is Analog Devices, there's a pretty good chance their stuff works.
Here's another one you can try.
Good luck with your quest!
03/05/2015 3:18 AM
You can't simply build a RF circuit from a circuit diagram.
In fact you can't even build a audio hi preamp just from a circuit diagram as I found out about 40 years ago.
If you are a newbie hobbyist, stick to audio, simple logic and low frequency stuff.
Start with something very simple, once you can understand that and make it work, progress to slightly more complicated stuff.
E.G a simple series regulated power supply using discrete components is a good and useful exercise.... you'll learn far more than if you just wire up a 78L05 , mind even that can go wrong with out the decoupling capacitors
03/05/2015 1:15 PM
Or for $50 you can buy this and be W - A - A - A - Y ahead of rolling your own.
http://www.amazon.com/KEDSUM%C2%AE-Range-Stereo-Broadcast-Transmitter/dp/B00D826PU6/ref=sr_1_15?ie=UTF8&qid=1425578162&sr=8-15&keywords=fm+transmitter
WARNING: These cheap inexpensive units are not plug-and-play. You will probably need to fiddle with them to get good performance.
I have one of these I run at 50 mW so I can 'carry' my music around the house or yard with just a simple FM Walkman or little boombox. They work pretty well provided you're careful with how you route the power cable relative to the audio cable because it will pick up hum very readily. I also added a split ferrite core (two wraps) to the power supply cable to kill the interference that the little switching power supply couples into the transmitter.
I found some unused spectrum down around 88.3 MHz and made sure I was in the low power setting. If I tune my car radio to my 'pirate' radio station, I lose the signal once I am about two or three houses away, so I don't believe I will incur the wrath of the FCC. (What's that clacking noise I hear on the pavement . . . . . ?)
I just got so tired of COMMERCIAL radio with its 8 to 10 minute blocks of commercials. I much preferred the old format where they played a couple of songs, then a commercial, then a couple more songs and so on. Weekends are especially bad on the radio.
Cheers !
03/05/2015 1:18 PM
I was thinking he was trying to build one of those short range FM spy bug transmitter circuits that you can pick up on your radio. Those are straight forward to build.
03/06/2015 2:54 AM
I mean you can't actually physically lay it out like the circuit diagram.
With RF, layout and construction is critical...
But I'm sure you know that, I just suspect the OP doesn't
Re: Working FM Transmitter Circuit
03/05/2015 9:05 AM
u should not be ask this type of questions because it is the site to clarify your doubts in concept not to ask the circuit diagram you should search in the search enginr
03/06/2015 10:52 AM
What about this, go to www.ebay.com and write
1000W RF Power Amplifier for FM Radio Transmitter,
they have tested boards from 5 W to 1000 Watt low price
=why to invented the wheel ?? You can buy also the POWER Transistors new or rebuild ! on ebay
ITS NOT CLEAR TO ME WHY CAN NOT =COPY AND PASTE= the link on this page??
Thanks-Daveross problem solver see youtube.
03/07/2015 10:41 PM
Thank you brave sir robin for providing ckt. I keep on trying on this.
Register to Reply 11 comments
Brave Sir Robin (2); daveross100 (1); IdeaSmith (1); jack of all trades (2); Lokeshloki (1); lyn (1); user-deleted-1105 (2); vijay guntimadugu (1)
