Previous in Forum: Working FM Transmitter Circuit   Next in Forum: Will You Buy an Apple Watch?
12 comments
90 Degrees Phase Shift for Input Signal
03/07/2015 10:55 PM
How to get 90 degrees phase shift for an signal practically. We cant use an inductor because it cant give 90 degrees perfect phase shift practically and a capacitor is giving me a 60 degrees only but not 90 so please give suggestions how to get perfect 90 degrees.
Success is a wall made by bricks called failures.
Pathfinder Tags: capacitor delay inductor phase shift
Re: 90 degrees phase shift for input signal.
03/07/2015 11:03 PM
Google gives you about 991,000 results.
We still don't do homework.
Good Answers: 141
03/08/2015 1:12 AM
It is difficult to give you an answer when you come up with this little info.
A coil- or a capacitor can give you practically 90 degrees when your RC or RL circuit is dimensioned the right way.
Plenty of room here
03/08/2015 4:03 AM
no info from me
03/08/2015 7:47 AM
Look up Op-amp integrators.
03/08/2015 8:35 AM
If the circuit you are trying to use to obtain a 90° phase shift is a single pole filter, then it cannot be done. One must have at least two poles to get a 90° phase shift. An induction motor run/start capacitor circuit is not a single pole filter. The motor is a much more complex impedance than a resistor.
03/18/2015 12:10 PM
I need 3 on mine. Hihihi
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 122
03/08/2015 11:28 AM
Here is a link to an excellent article on phase shifting control.
http://www.edn.com/design/analog/4326825/Microcontroller-controls-analog-phase-shifter
Re: 90 Degrees Phase Shift for Input Signal
03/09/2015 12:51 PM
What is the application?
What is the Frequency?
What is the power level?
03/11/2015 11:03 AM
1khz, 5v, current in some milli amps
03/11/2015 12:16 PM
Here is an audio frequency phase delay device for $ 100. You should use a two channel scope to assure that the delay is precisely 90 degrees.
http://www.uaudio.com/store/special-processing/little-labs-ibp.html
03/19/2015 12:25 AM
Iam asking the circuit.
03/19/2015 11:37 AM
Using BING, I found this circuit diagram. I would substitute variable R and C in the
output stage to get a tunable delay.
http://www.simplecircuitdiagram.com/2011/02/04/single-transistor-variable-0-180-deg-phase-shifter/
Register to Reply 12 comments
dvmdsc (1); Kulas (1); Lokeshloki (2); lyn (1); redfred (1); Rixter (1); SHOCKHISCAN (1); vijay guntimadugu (1); WoodwardDL (3)
