Previous in Forum: What is Difference Between Mass and Volume Flow   Next in Forum: Annubar Discrepancy
Impulse Response
03/12/2015 10:51 PM
Should Impulse response of any system start with one and zero. If yes, please explain
Re: Impulse response
03/12/2015 10:58 PM
Good Answers: 183
03/13/2015 11:40 AM
If you work on simulating a system you can generate an impulse as the sum of a positive step and a negative step with a time delay in between. Yous hould take care of the integration time step which should be small with respect to the delay between the 2 steps.
03/12/2015 11:03 PM
Is this for a linear, time invariant system?
03/12/2015 11:18 PM
yes. i am working with MATLAB, but i couldnt be able to find the inbuilt command for impulse response of filter impz will work for finite or infinite (FIR or IIR).
03/13/2015 1:34 AM
You might want to use 5.61 and 2.17 instead, and see what happens, Mildred.
Good moaning!
03/13/2015 8:10 AM
The impulse response is exactly what the name says. You put in a single "1" into the input and what comes out is the impulse response.
Register to Reply 6 comments
Brave Sir Robin (1); Crabtree (1); lyn (1); nick name (1); Rixter (1); sakthipriya (1)
