Environmental Technology Blog
The Environmental Technology Blog is the place for conversation and discussion about refuse and recycling, pollution control solutions, hazardous waste and remediation, and environmental sensors. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: OPEN SOURCE ZERO-WASTE ZERO-CARBON BUSINESS-MODEL (ZW-ZC-BM)   Next in Blog: Crusading for Wind Off Cape Cod
2 comments
APIX_PILOT PLANT (Based on Banana Plantation Resources) – PRODUCT-1
Posted January 12, 2010 1:30 PM by pvhramani
Our First APIX_PILOT Plant would be based on the conversions of about 60, 000 banana stems (about 450 T organic solids), along with 300 T "green weight" other organic materials (about 75 T solids). The following end-products are planned:
Please look here for better illustration: Banana Wastes Based APIX-SEP
  1. 192 KW Power (Heat & Electricity)
  2. 110 T Banana Fiber Molded Crockery
  3. 1170 T Carbon Sequestered Engineering Product (Molded Tiles)
  4. 99 T (Solids) Biofertilizer
  5. 2.95 T Green Sulfur.
COMMERCIAL/ SOCIAL HIGHLIGHTS
  • Expected ROI > 50%
  • Break-even is expected by first year end
  • Repayment envisaged in 4 years
  • All water, organics and CO2 recycled
  • Local village transforms into wealth creation center (there is scope for direct employment to 150 local people)
  • True Green Clean-Tech, Zero-Waste Zero-Carbon Business (No grid electricity used; no fossil fuel system used; no effluents/ wastage)
Energy and Molded Crockery are the primary products. The entire Power (both Heat and Electricity) would be utilized, insitu; and we shall not depend on either grid-power nor would there be any use of fossil fuels (as noted above).
60, 000 Banana stems/ agrowastes produce the following initial materials:
  • Fibrous materials (Banana fibers; 100 T used for Composite Moldings) ... 300 T
  • Non fibrous Organic Solids ….............................................................. 150 T
  • Recoverable water (Total = 2, 550, 000 L) …..................................... 2, 450, 000 L
350 T solids (Out of 450 T total solids from Banana plant wastes, both fibrous and non fibrous) + 75 T solids from the 300 T "Green" weight input of Animal/ Organic wastes (Total solids = 425 T) would generate 118 T methane gas. This in turn would generate 1, 387, 199.76 KWH (= 192.66 KW @ 24 hrs 300 day). This would be used entirely for the process operations. This saves a total of 252.47 T of Diesel/ Petroleum fuel, and offsets 732.163 T of CO2. Money to be saved in manufacturing = $190, 000
We shall now look at the Marketable products (one by one):
1. NFPC SUBSTITUTED MELAMINE MOLDED CROCKERY
This project would manufacture high value Fiber Substituted Melamine Molded Crockery (Fiber Crockery), wherein the base raw materials would be the fibrous portions of banana plants. It is noted that normally, about 50% by weight of the molding compound that becomes crockery is constituted by specialty paper/wood pulp. We shall replace this 100% by banana fibers. The environmental benefits and social benefits are enormous. While, a ton of standard Melamine Crockery would need pulp from about three tons of wood, one hundred banana plant stems (of average size, having non-fruit portion of 50 Kg) could replace the same [Here we may also note that 3.3 Tons of Banana Fiber Substituted Melamine Crockery would help offset one ton of CO2]. If the price offered for this agrowaste is $0.02 per kg, a local farmer could get a total of $100 (@ 50 Kg per stem green weight, average) for these hundred banana plant stems! At present nothing is earned on the banana stem. In fact, each ha of banana plantation would have between 2, 150 to 2, 250 stems. If we consider only 2, 000 as the average available, every ha of banana plantation would fetch (@ 50 Kg per green stem, including all leaves and roots) not less than $2, 000 for mere agrowastes! These could be converted into not less than 20 Tons of Fiber Crockery (valued $146, 000 in the market). Note: In practice, as we have various other ingredients added to the molding compound, each ton of dried fiber could be converted into 2.2 T of Fiber Crockery. This project would convert 10, 000 banana stems (50 T fibers) into 110 T of Fiber Crockery. We shall produce the following: One 24 pcs Set of Tableware consisting Four Full Plates, Four Half Plates, Four Cups & Saucers, and Four Soup Bowls & Spoons … net wt = 2.02 Kg per "set" (total 54, 455 Fiber Crockery Table sets) … valued @ $14.746 per Set
We shall look at every other such product in this APIX_Pilot Plant, one-by-one, over the coming days
Re: APIX_PILOT PLANT (Based on Banana Plantation Resources) – PRODUCT-1
06/03/2011 7:50 AM
Dear Sir,
I would be much obliged if you can send me the company/ institution who is providing this facility.
I am from Maharashtra, India which grows a huge amount of Banana.
THanks and regards
Vasudev Nair
CR4 Admin - email address removed - please share email addresses using the Private Messaging system
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
APIX Pilot Plant Design Project - Member - New Member
06/03/2011 9:51 PM
Hello Vasudev Nair
Thank you for the interest
Please do proceed to the following links that would give you more details:
http://zerowastezerocarbon.wordpress.com/
http://agrobiogenicscleantechpvtltd.com/
Thanks again
pvhramani
Our values have to be measured by what we could offer to the society and to the world, when a "balance sheet" is drawn up at the time we leave our "foot prints on the sands of time".
You might be interested in: Fiber Optic Cables, Fiber Optic Connectors
