It's not at all a staightforward question. The answer is always
"it depends on the generation." The distinct design of each of GM's sister
ponycars varied so widely throughout the generations that it's hard to
imagine maintaining a single favorite during the entire 40-plus-years
of their history. To complicate matters, drivetain and trim packages
varied significantly as well, with sometimes the Camaro, sometimes the
Firebird packing the more desirable goodies.
Terminal Indecision
While there are always
some folks who are die-hard Camaro or Firebird fans, the whole issue
gives the rest of us a case of terminal indecision. And when you
consider that even the final dismantling of Pontiac may not spell the
end of the Firebird (if the aftermarket has anything to say about it),
the rivalry will likely continue for successive generations.
Which Do You Prefer?
So here's the question: out of Camaro or Firebird, which do you prefer?
Are you a true-blue supporter of one or the other, or do you waver back
and forth depending on what years we're talking about?
Read the Whole Article
