Speaking of Precision Blog
Previous in Blog: Prices Rise as Manufacturing Recovers   Next in Blog: Three Ways to Find Information on Bolt-Grade Steels
8 comments
5 Things To Know About Triangle Effect, Pseudo-Roundness, and Lobing
Posted September 14, 2010 9:00 AM by Milo
Pseudo-roundness is best defined as any shape not perfectly round, which exhibits constant dimensions when measured in any direction between two parallel planes (i.e., with a 2 point micrometer).
  1. A non-round (pseudo-round) workpiece can mike as if it were round using only customary two- point, two- plane gage;
  2. A pseudo-round can be detected with a three-point gaging system;
  3. Given the number of lobes from using a 90 degree V-block and indicator, a savvy shop hand can choose the proper included angle V-Block to determine the difference between R and r;
  4. Salvage of individual parts is possible given sufficient stock to remove;
  5. Bars exhibiting lobing can be ground to the next incremental size and the lobing eliminated with attention to details of wheels settings, support plate location and geometry, and rotational speed.
In centerless grinding, a geometric condition can be encountered that puzzles most shop hands and often stumps the old pros. That geometry condition is called pseudo-roundness, lobing, or the triangle effect.
Triangle effect is also called 'lobing'
Pseudo-rounds have odd numbered crests, which because of the exact opposition of their high to low spots always have a constant "Miked " Dimension. This is explained by the fact that the gaging planes of R and r are tangent to the arcs of the profile, and perpendicular to both radii which belong to the same common center. That is:
Miked Dimension = R (center to apex) + r (center to low spot)=Constant value
I first encountered this when I had a batch of material that miked fine but didn't pass the customer's roundness test. That material was lobed.
I'll spare you all the geometry lesson, but here are a half dozen facts that I know from my 30+ years experience in the bar business:
  1. Everybody will tell you it can't be fixed. They would be wrong. Round gage pins are held to millionths of an inch of roundness, and they didn't start off life at that level of perfect roundness before grinding
  2. Yes, it seems impossible to be able to fix it if you know that the centerless grinder has the high spot hitting the regulating wheel while the pressure from the grinding wheel holds the work down against both the regulating wheel and the blade support, since the diameter obtained in centerless grinding is determined by the distance between the regulating and grinding wheel. But as I mentioned above, the fact that a constant diameter results does not assure perfect cylindricity.
  3. In order to assure a more perfect circle, adjustments of the geometrical arrangement of the grinding and regulating wheels, support blade need to be made. In my experience, increasing the speed of rotation also seems to help.
  4. While you can regrind to eliminate the lobing, that doesn't mean that A) it will come in both round and B) within your originally desired tolerance. Unless you have left a great deal of stock on the workpiece, there is usually insufficient material to true up to your hoped for diameter.
  5. Use a three-point micrometer if roundness / cylindricity is a critical feature on your product. The sketch above shows you how a constant diameter solid workpiece can in fact not be a perfect circle. A two plane gage will not reveal this to you.
  6. A standard 90 degree V-Block and indicator will do, but if you want to measure the difference between R and r (R-r) you will need V-block of the angle given by the following :
2A = 180-(360/N)
where N is the number of high points or lobes. For a three lobe configuration, A becomes 30 degrees, (the half angle) and the V-Block should be 2*A or 60 degrees included angle.
Kennedy and Andrews.
Editor's Note: CR4 would like to thank Milo for sharing this blog entry. If you're attending the International Manufacturing Technology Show (IMTS), be sure to look for him there! Milo will be at IMTS Wednesday, Friday and Saturday at Booth W1943 (West Hall).
Re: 5 Things To Know About Triangle Effect, Pseudo-Roundness, and Lobing
09/15/2010 10:34 AM
Don't know if this has a place here, but it's quite interesting
http://en.wikipedia.org/wiki/G%C3%B6mb%C3%B6c
Good Answers: 243
09/15/2010 10:23 PM
Indeed. Leave it to a squirrel to come up with a reply on degenerate / non degenerate shapes! Thanks for that. Could you imagine what a certain cat might do with one of these? Milo
09/16/2010 2:42 AM
Cats always land on their feet (this has been tested in a Basildon tower block), and so the very concept of mono monunstable would be alien to them. Spread butter on ones stomach, launch it, and behold what happens .
Good Answers: 130
09/15/2010 11:40 PM
Ar that takes me back - Metrology - loved that stuff - all those toys and shiny slip together thingies and 'why is it so' and how a meter is kept a meter, a yard a yard, and that guy Arie.
Thanks Milo
09/16/2010 5:07 AM
The UK fifty pence and twenty pence coins are deliberately curves of constant width.
Good Answers: 243
09/16/2010 7:14 AM
Santayana said it is helpful for a system of philosophy to be true... The odd number of facets on this coin was a defining characteristic in our description of what we called a pseudo round. Thanks for providing some local expertise on this subject. Milo
09/16/2010 7:00 AM
How cum Lobing or Traingle Effect happens in Centreless Grinding. I shall require cross-sectional sketches on the subject. Centreless Grinding is paraforced generative process of removing fine material and it is difficult to go out of Cylindricity in centreless grinding. Explain!
09/16/2010 10:24 AM
I've also noticed something very similar to this if one tries to drill a hole in sheet metal using a hand held pistol drill with a standard twist drill bit.
These come in handy to address that problem
Register to Reply 8 comments
34point5 (1); ANIRUDDHA_HARSHE (1); Brave Sir Robin (1); Kris (2); Milo (2); Randall (1)
