Speaking of Precision Blog
Previous in Blog: 5 Things To Know About Triangle Effect, Pseudo-Roundness, and Lobing   Next in Blog: Seven Advantages of Friction Welding
Three Ways to Find Information on Bolt-Grade Steels
Posted September 17, 2010 9:00 AM by Milo
Many times a print will come in to be quoted with material called out to be "Grade 8," "Grade 4.8, ", "B7″ or something similar.
Where can you find the material, chemistry, process, and mechanical requirements when given these 'clues?'
Externally threaded fasteners is what we are blogging about.
Hint number 1: If the dimensions are customary US units, try SAE J429 Mechanical and Material Requirements for Externally Threaded Fasteners. J429 calls out grades 1, 2, 4, 5, 5.1, 5.2, 8, 8.1, 8.2 J429 is available from SAE. J429 link.
Hint number 2: If they are metric, try SAE J1199 Mechanical and Material Requirements for Metric Externally Threaded Fasteners. J1199 calls out 4.6, 4.8, 5.8, 8.8, 9.8, and 10.9. J1199 is available from SAE here. SAE J1199 link.
Hint number 3: Bolts with a "B" prefix like B7, B7M, B8, B8A etc can be found in ASTM A 193 Alloy Steel and Stainless Steel Bolting Materials For High Temperature Service. available from ATSM. A193 link.
These are covered by the bolt specs, too.
One final thought. These are not the only sources of bolt grade designations by number. ISO 898-1 is another document for metric bolting materials.
Photos credit- PMPA Active Member Huron Automatic Screw Company.
Good Answers: 213
Re: Three Ways to Find Information on Bolt-Grade Steels
09/17/2010 10:37 PM
Once upon a time, the Machinery's Handbook had all of this information in nice, concise format, including references to the appropriate standards. I don't know if newer versions of the Machinery's Handbook includes this level of detail, however.
