Previous in Blog: Superbug Spreading in U.S., World   Next in Blog: Standard-Definition TV Is Getting Hard To Watch
2 comments
How to Turn Toxic Gunk into Glass
Posted September 15, 2010 7:57 AM
From PopularMechanics.com Science - RSS Feed:
Toxic sludge cakes the bottom of the Gowanus Canal. Snaking through Brooklyn, New York, the canal is a newly EPA-designated Superfund site. To clean the 300,000 cubic yards of mud mixed with industrial metals, coal, tar and sewage, the EPA will most likely have to dredge the waterway over the next decade. The question that remains is what to do with the muck once they dig it up. One option that the agency is considering is melting the ooze into something both non-toxic and surprisingly attractive: washing machine-sized glass cubes. Using a process called vitrification, the agency could put the sludge in metal molds and heat them up to very high temperatures. If there is enough sand in the material, the result will be transparent blocks that can be used in building construction or sculptures.
Re: How to Turn Toxic Gunk into Glass
09/16/2010 11:23 AM
I'm surprised they are going to dig it up. That process usually causes more problems than it solves. It's just like the vermiculite insulation in my attic that probably has asbestos fibers. Better to simply let it be.
09/16/2010 11:30 AM
Actually it is a nothing story - nothing new or informative.
Westinghouse carried out a lot of work on this years past using a plasma fired cupola to vitrify nuclear waste. I visited their tech center outside of Pittsburgh during one of the trials.
Perfectly possible to use but expensive.
Nothing worse than a 'reporter' who needs a story but has zero idea on what to write. Today with the internet they can always dust of some crap such as this, add a small amount of BS to make it original and presto - something to publish!
