Hemmings Motor News Blog Blog
Previous in Blog: Cool Cars: 1909 Walker Model 15   Next in Blog: Amphicars: Aquatic Automobiles
3 comments
Repairing Cracked Blocks and Heads
Posted September 20, 2010 12:47 PM by dstrohl
"One of the most frustrating problems encountered during the restoration or repair of a vintage automobile is scarcity of engine parts. When a vehicle has been out of production for a decade or more, there are only so many blocks, crankshafts, connecting rods and cylinder heads remaining in existence. And like land, they aren't going to make any more.
But if you're the proud owner of a head or block that seems usable as little else but a door stop or oversized paperweight, you may be able to circumvent the time, effort and expense of locating a replacement."
The 1980s seem to have been a great time for DIY because it appears DIYers never had any idea they couldn't do something. Cracked block or head? I'll just weld it up. But it's made of cast-iron? Okay, so I'll weld it up at face-melting temperatures. Dave Emanuel showed us how race engine builder Al Dicksen did it in an article from December 1983.
Read the Whole Article
Re: Repairing Cracked Blocks and Heads
09/21/2010 2:58 PM
We used to weld cast iron on tractors a lot back in the late 60's and early 70's on the farm. The trick was to chase the crack quickly with a low temp rod. Ofter you would create new, smaller spiderweb cracks off of the original crack but when you got one closed up to just at it's end, you would then stick the welding rod straight into the end of the crack and break it off. Grind her down gently and paint it. Almost good as new.
Good Answers: 114
09/22/2010 1:41 PM
Oops, sorry. I thought this was about the mods.
09/22/2010 5:03 PM
Ooooh! Ouch. That's harsh!
129CBRider (1); Doorman (1); passingtongreen (1)
