When machining carbon and alloy steels, Crater Wear is the normal tool failure mode. Overheating is an unpredictable failure mode. It can be one of two failure modes, Thermal Checking ( or Cracking- my first boss called it "Crazing" ) or Deformation.
Usually, when an irate customer ran into overheating issues, the tool
they sent back to me had deformed to the point that it looked like it
had been made out of lava.
The lack of predictability of failure by overheating creates
issues for the shop beyond the obvious. Parts produced immediately
prior to failure are suspect and must be validated prior to release, to
avoid sending rejectable product to customers. Overheating can thus be a "delivery problem" in your customer's eyes.
Here are 5 tips to get out of Overheating Tool Failure Mode and back to normal predictable Crater Wear Tool Failure Mode when machining steel:
- Improve lubrication coolant delivery or formulation.
Sometimes adding an extra coolant line to the position will eliminate
the problem. Confirming your coolant is up to spec should be done
before electing to buy a new "super duper formulation." First things
first!
- Use a harder grade of carbide with more Ti (Titanium)
- Increase the Feed Rate (IPR) inches per rev
- Reduce the Speed (SFM)
- Consider Ceramic or Cermet Tooling. Note- these are not really appropriate for low carbon (less than 0.20% C) steels. Low carbon steels become gummy and stringy at speeds typically used for ceramic tools.
These tips will address your overheating problem by reducing the
friction, surface adhesion, and improving removal of heat, (improved
coolant, delivery); improving the tool's ability to withstand cutting
conditions, and reducing the heat inputs by decreasing speed and
increasing feed.
For more great information on this subject look at this lesson from Fox Valley Technical College.
