Mechanical Components Blog Blog
The Mechanical Components Blog is the place for conversation and discussion about parts, tools, and hardware such as bearings and bushings, tools and testing, materials and industrial hardware. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Farewell, Prototype Testing   Next in Blog: 3D Printing Reaching Its Limit?
3 comments
These Bolts Aren’t Dolts
Posted December 16, 2010 9:00 AM by Sharkles
Bolts are one of the most common ways to fasten two piece parts together. They typically require a torque wrench to be tightened to the required degree, often determined by an engineer. Should a bolt be too lose, a piece may move around; if it's too right, it may not move at all and could even damage a part.
In some cases, it can be difficult to gage whether a bolt is properly tightened. However, by using technology developed by the International Space Station's Material Science Laboratory, Intellifast has created a bolt that contains an ultrasonic sensor in the head that can measure the amount of stress placed on a piece when in place.
Technicians attach a meter to preform an ultrasonic scan and measure the strain on the bolt. The meter can also be attached to a torque wrench to allow the amount of strain can be tracked as it's screwed into place. These new space-inspired bolts are to be used in manufacturing of lighter and safer cars.
Source: European Space Agency
Re: These Bolts Aren’t Dolts
12/16/2010 11:23 PM
there are bolts that have a double bolt head,1 on top of the other. the bolt has a specified torque. you tighten the top bolt till it snaps off. at that point you are where you want to be. if you need to take it a part you still have the other head. they have been around for years. most common i have seen are used on mj fittings.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
12/17/2010 7:25 AM
Unfortunately the relation ship between torque and bolt tension is very poor even under perfect conditions; throw in mechanical tolerances and minor contamination and it's terrible that's why this method for attempting to measure the actual tension in the bolt is being introduced.
03/19/2011 9:03 AM
I wonder if this new technology will have a compensation for mechanical failures... Anything mechanical will eventually fail, some by inherent design. A failure of one device will effect more strain on a connection, which may cause failure. This is why engineers will have a tolerance in design - to allow for possible "up-stream" failure.
This new technology could eventually lead to companies designing with this minimal requirement.
darren2264 (1); Kenholl (1); Randall (1)
You might be interested in: Bolts, Bolt Tensioners, Anchors
