Mechanical Components Blog Blog
The Mechanical Components Blog is the place for conversation and discussion about parts, tools, and hardware such as bearings and bushings, tools and testing, materials and industrial hardware. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Energizing the Era of the Exoskeleton   Next in Blog: Plugging the Gaps in Wind Power Efficiency
A New Era Unfolds in Metal Machining
Posted October 05, 2015 12:00 AM by Engineering360 eNewsletter
Engineers at Purdue University have discovered an unknown phenomenon of metal deformation. Using high-speed microphotography during metal cutting, researchers capturedsinuous flow, that is, the folding of metal when it is being cut. The images contradict a long-held assumption that metals shear uniformly when being cut. While surprising, the research also provided a positive outcome: the team developed a simple and inexpensive way to suppress sinuous flow. The method, which involves painting metal with marking ink, could lead to faster and more energy-efficient machining.
To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Mechanical Components today.
Re: A New Era Unfolds in Metal Machining
10/06/2015 9:54 AM
Very interesting. The sinuous folding is not surprising, a form of galling at micro scale, but how a coating of micron(?) thickness on the surface of a ductile metal of mm thickness would afford such a benefit in shearing (sawing) effort reduction is almost spooky...if I am reading the Purdue article correctly.
