Hemmings Motor News Blog Blog
Previous in Blog: Cool Cars: 1956 Cadillac Eldorado   Next in Blog: Harley Knuckleheads and Motorcycle History
2 comments
Can You Explain How This Engine Worked?
Posted January 31, 2011 10:45 AM by dstrohl
It's been a few months since we posted this photo of a mystery engine, and we're no closer to a solid answer explaining the engine's design now than we were back then.
So here's what we know. The photograph's caption identifies the man as Giuseppe Merosi from Alfa Romeo. The magneto (toward the right of the photograph) only has two leads, to what appear to be the rear-most two cylinders. The intake appears to be common among all six cylinders (snaking upward to meet the two rearmost cylinders), and each cylinder appears to have its own appropriately sized exhaust pipe. What's most unusual about the design of the engine is that the forward cylinders appear to have just one valve per cylinder.
Read the Whole Article
Good Answers: 39
Re: Can You Explain How This Engine Worked?
01/31/2011 11:58 PM
What's your reason for thinking the power cylinders only have one valve. It looks like an F-head engine, with one valve in the block, and one in the head. I think some Jeeps or Land Rovers had this type of engine. The other four cylinders could be air pumps. Maybe that's when the gauge is for, monitoring the air pressure. Or maybe it's an early air-gasoline hybrid. And why is the intake so small, and not tapered? Where's the intake air filter or pickup? Or possibly, it's a gasoline start, diesel run engine, like the foghorn air compressor at East Brother Light in San Francisco Bay. I'm wondering if both engine share a crankshaft, with an overrunning clutch, or perhaps the levers at the front are a clutch mechanism to disengage the diesel from the gas starting engine.
Align culture with nature...
02/01/2011 3:04 AM
What about a 2cycle aircraft engine with two large scavenging blower cylinders? I would be willing to bet no one had yet invented vane type superchargers or turbochargers at the time the photo was taken. It looks like a WWI (or possibly earlier) aircraft engine prototype to me. I know they were experimenting with 2cycle injected gas engines trying to achieve better performance in the thin air at higher altitudes.
