Industrial Processing Equipment Blog Blog
The Industrial Processing Equipment Blog is the place for conversation and discussion about fluid and gas handling equipment; thermal processing; solids handling; and filtration, separation and recycling. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: What Will We Learn from the Deep Water Horizon Report?   Next in Blog: Biofuels: Boon or Bane?
3 comments
Standstill over Processing Equipment Delivery Ends
Posted February 10, 2011 8:15 AM by Sharkles
Residents and business owners in northern Idaho have been acting as a joined force in effort to block shipment of massive oil processing equipment from passing through their communities. The group has been working to prevent the shipments since fall 2010, but have been told to back down.
The issue began when resident Linwood Laughy realized that oil giant, ConocoPhillips, would be using the Idaho back-roads as a way to ship equipment to Vancouver, Washington, Montana, and Alberta. This route would allow the oil company to save time and money in transportation expenses, as they'd otherwise have to go through the Panama Canal to other overland routes.
Laughy noted that the shipped loads were too large to move quickly; in fact, the ~600,000 lb., three-story tall, and 24 ft. wide shipments would move so slowly that the both lanes of the highway would be blocked for nearly 100 miles when they passed through.
Along with his wife Borg Hendrickson, Laughy filed a lawsuit against the state of Idaho to stop the shipments from Conoco, as their driveway intersects with the route in question. In their lawsuit, they argued that using this route would "threaten the integrity of Idaho's historic portion of U.S. 12 [some of the last remaining tracts of wild land in the country]" and the safety of the communities who depend on the highway as their main road.
Revised Permits
Amidst litigation, the oil company worked with state transportation officials to refine the proposed route and shipment qualifications. The permits now allow Conoco to move two coke drums that are split into four shipments across Idaho and into Montana. Transportation of the loads is to be done in stages, at night, and at low speeds. The guidelines also include regular pull-outs that will allow traffic to flow normally and reduce blockage.
These new guidelines became official after residents failed to persuade regulators that the route should be completely blocked. Hendrickson told The New York Times that the group plans to focus their energy on larger procession of oil processing equipment that is believed to be waiting in the wings. They continue to fight against the transformation and use of historical rural routes into an "industrial corridor."
Source: The New York Times January 2011, October 2010
Re: Standstill over Processing Equipment Delivery Ends
02/10/2011 4:31 PM
Cut off their fuel until they shut up.
Or bulldoze out all the blacktop and turn it back into a historic dirt trail.
02/10/2011 10:39 PM
If I was ConocoPhillips I would take my DOT heavy load permit and roll it up real tight and jam it up their... Well anyway they would get a good up close read of it.
02/11/2011 12:01 PM
This type of problem is common in the UK, and the protesting people are called NIMBY's (not in my back yard), but I'm sure the people who are protesting wouldn't mind the oil products when the processing equipment is up and running, even buying some of them!
tcmtech (1); Tornado (1); xanasax (1)
