Previous in Blog: U.S. Loses Top Spot in Global Tech Study   Next in Blog: Mysterious Debris May Be Meteorite
4 comments
Scientists Bend Liquid with Power of Light
Posted March 28, 2007 6:46 PM
From Seed Magazine:
Chicago (AFP)—A group of scientists have found a way to bend and direct liquid using only the force of light, according to a study that will be published Friday. The French and American physicists used a laser beam to produce a surprisingly long and steady jet of soapy liquid that was narrower than a human hair. When directed at a different angle, it pushed the liquid into a hump-like shape. It is believed to be the first time a laser had been used to generate bulk flow in fluids.
Re: Scientists Bend Liquid with Power of Light
03/29/2007 11:19 PM
In the linked article, Prof. Wendy Zhang wouldn't disclose the identity or nature of the so called "liquid". Is it of some electromagnetic properties, to be influenced by this laser beam?
Then she goes into a description related to radiation pressure, which would make sense given the high velocity photons of laser, doing something to the liquid's surface tension (but what?) and so on.
The only practical implementation there, pops at the end of the article, as: "...controlling fluid flow through channels thinner than a human hair...", Which is good news frankly, provided it's there for the taking, not some extrapolation.
The apparent coherence of the liquid movement, may have to do with it's (chemical) molecular bond changing energy level or cohesive orientation.
So, Dear Wendy, What is this liquid?
03/30/2007 9:31 AM
Now we can interface fluidic amplifiers with photonics!
03/30/2007 9:45 AM
Provided it's not some wild speculation on their part
03/31/2007 3:37 PM
It makes sense that light energy could deflect water if it is composed of particles, and if photons have mass (momentum), but do they? Here it seems that they broke up the surface tension of the oil and water mixture.
Anonymous Poster (1); StandardsGuy (1); Yuval (2)
