Quality Control Blog
Quality Control
The Quality Control Blog is the place for conversation and discussion about product inspection technology, quality control methods & software, quality standards and compliance testing, defect prevention analysis. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Who's Better: Ford or Toyota?   Next in Blog: What Makes a Good Black Belt?
8 comments
Emphasis Needed on Quality Control to Reduce Recalls
Posted February 22, 2011 3:08 PM by Sharkles
Last year, the automotive industry saw a number of recalls from major manufacturers, including Chrysler, Nissan, Honda, GM, and Toyota. Antony Bourne of AutomotiveWorld questions why there have been so many recalls in recent years. He suggests that changes in the manufacturing process have prioritized the idea of "efficiency" over quality control. As a result the new "efficient" processes may actually result in logistical challenges and financial losses.
Bourne gives two examples: part-sharing and lean manufacturing. He writes that the increased reliance on part-sharing means that when a part needs fails, it has a much bigger impact than previously. So while this practice may benefit inventory levels and purchasing costs initially, that savings is insignificant in the face of a recall.
Lean manufacturing also factors into the number of recent recalls. Lean principles stress having reduced inventory levels and a preference for supplier consignment stock. Manufacturers don't always check the quality of the supplier's stock until the time of use, resulting in significant disruptions if it's not up-to-par and production plans need to be reconfigured.
To remedy these issues, Bourne calls for manufacturers to prioritize quality control across their entire supply chain. He also recommends "vigorous supplier audits" to ensure that suppliers aren't cutting corners. By emphasizing quality control, it will reduce the risk of recalls and ultimately minimize associated costs.
Does your company emphasize quality control?
Source: AutomotiveWorld
Re: Emphasis Needed on Quality Control to Reduce Recalls
02/22/2011 4:18 PM
Oh my goodness!!!!
This so called expert should be sent home to at least become familiar with the terms that he uses (and abuses). What a joke!!
"Quality control" is an old and obsolete terminology. It has proven itself to literally guarantee failures. "Quality Assurance" is the methodology that should be discussed, and the automotive manufacturers very much understand the difference.
Then his comments on "Lean" and at the same time talks of "consignment stock" show a complete lack of understanding of the automotive manufacturing industry.
Then finally, he talks of "rigorous audits". Heck, I'd rather a Lloyds quality and environmental third party audit, or even a NIST laboratory audit than a second party audit by the auto manufacturers. As second party, they not only know how your system should be working, but the actual outcome and SPECIFIC issues that affect them.
I don't know where this guy came from, but it would seem his opinions are not founded in significant industry experience.
Sorry for the rant, but the article just hit a few of my buttons.
02/22/2011 6:00 PM
what efficiency are they referring too?
Customer support is far from efficient.
Fuel consumption is dropping on GM vehicles faster than they know what to do with so thats not a gain in efficiency.
Perfect in a computer simulation fails dismally when applied to real life working conditions so thats not gain in efficiency of design.
02/23/2011 5:06 AM
Good point, the design cycle is so short these days and they rely so heavilly on simulation and accelerated life testing neither of which will actually simulate the degradation of the multide of body earthing points which will doubtless screw up the overcomplicated electronics/software in 7 years time.
Yes guys, you guessed it, by damn Nissan Micra is isn't letting me lock the doors, because it's decided I havn't really switched off the ignition and it won't recognise the 'Intellikey' (a missnomer of the first order). Do I really want to risk putting it into the garage for repair when it's only worth £2k and they'll doubtless just change n+1 'modules' without actually finding the fault and charge about£800 for their effort?. Maybe I'll just threaten it with my longbow and try the old dissconnect the battery for 10 mins trick...I wonder if Microsoft had anything to do with their software?
<click, rant mode off>
India - Member - New Member Engineering Fields - Electromechanical Engineering - New Member
Good Answers: 53
02/23/2011 5:16 AM
There is no reason to fail if the quality control system is implemented with full sincerity,
02/23/2011 5:23 AM
Hi, I'm maybe thinking of buying the new Nissan Micra (it's more economic to run) as long as they have done away with some of the silly electronics.
It's now being made in India, maybe you could go and have a look, see if the quality is being implemented sincerely?
Some of the other top end Nissan models are still being made in the UK.
I did look at the possibility of an electric car but they still aren't really available.
I must check up and see what happened to that little Indian city car, the Nano wasn't it? It certainly looked promising.
Good Answers: 53
02/23/2011 5:39 AM
Oh, no problem from my side If you wish I ll request them for QS audit and send an audit report to you, About electric car I am not sure if anyone is producing here that is suitable for English cat,
Small nano is doing good and they have new plant in operation with capacity 250,000 units/year, for many people it is much more than a city car,But I am not sure about the progress on the exportable to Europe models,
02/23/2011 7:27 AM
Automobiles used to be machines that were designed by people with a mechanical background. Everything, from under the hood, to the hand crank windows, were designed to work, and easy to fix if they didn't.
Any of us that owns and uses a computer knows that the more cars are designed by computer people, rather than mechanical people, the less reliable they will become.
02/23/2011 7:56 PM
In many ways a load of the quality control or lack there of is the engineering persons or entire department that never bother to think that what they design may possibly be used in some other environment in an entirely different level of work load than what they themselves would use it for.
A great example I recently got first hand experience with is a good friend of mine just bought a brand new Chevy 2500 with the new urea based diesel emissions system on it. What a horribly designed piece of engineering junk!
The urea mixture freezes at around 12 F which is far above what our North Dakota winter temps average day in and day out. If the emission system does not cycle after so many miles or run time it goes into a safe mode where it will not go over 55 MPH until they system cycles. If it is driven long enough that way it goes into a second creep mode that wont go over a few miles an hour until a dealer service place resets the computer.
The urea tank can not be topped of until the tank is empty or it somehow screws up the computer and it goes into the limp modes due to some idiot deciding that the tank itself doesn't need an an actual sensor that reads anywhere between full and empty. Also that urea tank on a heavy duty off road designed vehicle is made of plastic and hangs down out in the open several inches below the frame on the right side.
The new and improved shift linkage is routed in such a way that when snow gets on the transmission it melts and then refreezes around the cable and linkage effectively locking it into place until the vehicle is either left in a heated building over night or someone crawls under it and beats the ice off the linkage with a big hammer.
Lastly for service and customer support they give you On star with is about as useless as talking to yourself in regards to what help they can actually give you if there is a real problem. Plus to pour salt onto the customers wounds the Chevy Lemon law states that the vehicle must be out of customer use for 30 days or longer at an authorized dealership for the exact same problem.
You can own it for 40 days and have it at the dealer for 35 of it but if those 30+ days it was down were to fix more than one problem its not really a lemon according to them.
Emissions system problems four times 14 days total shift linkage issues 3 times and 5 days total, mystery electronic engine management issues 3 times and 9 days total, Drive train related issues twice and 6 days total. Yes the will say it was there for 35 of the 40 days since it was purchased but not one single problem added up to over 14 days so by their reasoning thats not a lemon and thanks for spending $50,000+ on our top of the line work truck and please come again.
Just an Engineer (1); kramarat (1); rakesh_semwal (2); tcmtech (2); user-deleted-1105 (2)
