Drives Blog Blog
Drives Blog
The Drives Blog is the place for conversation and discussion about Drive Advances & Applications; AC & DC Motor Drives; Drive Tools & Technology; Drives for Motion Control. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Smart Makes First U.S. Delivery   Next in Blog: The End of Flash Drives?
3 comments
Drive Refurbishment Improves Uptime at Paper Plant
Posted March 07, 2011 1:01 PM by Sharkles
UPM Shotton Paper relies on a series of drives to feed paper machines for the production of more than 500,000 tons of newspaper annually. The reliance on these drives coupled with the desire to cut costs and reduce downtime led the company to investigate a refurbishment program from ABB in Sweden.
ABB began by identifying reasons behind the downtime of the low voltage AC drives. They initially believed that spikes in the power supply network may be harming the drives' semiconductors, but a network analysis disproved that theory.
After another failure, a drive was sent in for full analysis. From that, engineers deduced that the drives had dry solder joints on the power semiconductor units. Over the course of six months, ABB took UPM's drives four at a time and refurbished them. As part of the refurbishment process, they replaced power semiconductor modules and fans in the 36 drives.
Each drive was finished in a day and then underwent batch testing before it was returned to UPM. Since the drive makeover, UPM reports that they've seen an increase in drive reliability and decrease in downtime and costly repairs.
Do you refurbish drives or replace them?
Source: Plant Engineer
Re: Drive Refurbishment Improves Uptime at Paper Plant
03/08/2011 2:45 AM
Fans are cheap, but power modules sound rather expensive, to say nothing of control cards. If an expensive refurbishment forestalls an expensive repair later, how much money is actually saved? Too bad no comparisons were given.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
03/08/2011 3:45 AM
It would be interesting to know the age of the drives and whether they used lead free solder.
Canada - Member - Specialized in power electronics
Good Answers: 80
03/08/2011 8:44 AM
My understanding of RoHS is that large industrial electronics (same for military and aerospace) are exempted as the reliability and life expectancy are too important. The amount of lead is also small with respect to the weight and quantity of equipment produced.
Unfortunately, most electronic boards fabricators have switched to lead free (even on NA) which has caused a reduction in reliability. We uses to get a fraction of 1% of our boards failing the thermal chamber test. The last batch that is RoHS compliant (not really our choice, we didn't know better) has more than 5-10% rejects. It might be that my board supplier did a bad job setting his process but it seems that we are not the only ones.
My nightmare is that boards that passed the thermal cycling test end up developing problems later before their 20 years expected life time.
Has anybody else noticed an increased in soldering problem from the new solder and connection plating?
It looks like ABB is feeling the pain. What about the thousand of other customers who bought these drives and don't have the weight to make ABB fix them? What about the other drive manufacturers?
Experienced is earned, common sense is taught, both are rare essentials of life.
Chankley (1); marcot (1); Tornado (1)
You might be interested in: DC Motor Drives, Hard Drives, AC Motor Drives
