As a steel company Metallurgist and Quality Director, I was the guy
who got the call to visit a shop because the material we sent wasn't
machining right.
"This stuff won't drill! Help!"
"This stuff is killing my OD form tool. Can you check the steel?"
"This steel you sent is acting crazy. It machines fine on one machine, but not on the other one."
As the fellow responsible for the processes and quality system that
produced the bars, and having visited my hot mill upstream suppliers, I
was always confident that I had provided conforming product.
But how could I make sense of the problems reported?
Listen! There is a reason they have canaries in the coal mine.
My solution was to always look at the wrong tool - first.
If they complained about the drill, I asked them to show me the cut off tool.
If they complained about the rough, finish form, or shave tool, I asked them to show me the cut off tool first.
They said "Hey Mr. Free, you aren't paying attention. I said the drill is giving me trouble, not the cut off tool."
To which I cheerfully replied "Yes?"
After letting that sink in for a bit, I would ask the following appreciative inquiry type of question to lead their thinking:
"If the cutoff tool sees every aspect of the steel provided -
the very surface of the outside diameter (OD), the sub-surface, the
mid-radius, the core, and it does not have any abnormal issues
resulting from this material - what is there about this material that you think would allow it to affect this one tool, but not the cutoff?"
Then we focused on the aspects of the operation that inevitably were found to be the cause.
How does the steel know to only interfere with the drill, let's
say? Or the the finish form? While leaving the cut off tool unscathed?
While there can be material conditions that are specific to a
certain zone in the steel and thus would manifest on a particular tool,
that conditon would also have an impact on the cut off.
If the cut off tool is A-OK, it's probably not the steel.
This is the tool that will tell the tale.
It may not look like a canary, but a cutoff tool can sing a song about your process, if you can listen with your eyes.
Canary.
Cutoff.
