1) Martensite is the hardest and
most brittle microstructure obtainable in a given steel.
2) Martensite hardness of the
steel is a function of the carbon content in that steel.
3) Martensite results from cooling
from austenitic temperatures rapidly by pulling the heat out using a liquid
quenchant before pearlite can form.
4) As quenched Martensitic
structures are too brittle for economic use-they must be tempered.
5) Reheating as quenched
Martensite to a temperature just below the AC1 results in the best combinations
of strength and toughness.
This is
what you get when you cool faster than the critical cooling (pearlite
transition) rate - Martensite
Hardness of
martensite is a function of carbon content
Softening
of martensite in 0.35%C, 0.8% C, and 1.2% C carbon steels by tempering at the
indicated temperature for 1 hour.
Because Martensite transformation
is almost instantaneous, the Martensite has the identical composition of the
parent phase, unlike ferrite and pearlite which result from a slower
chemical diffusion process, which each have different chemical
compositions than the parent austenite.
Formation of
Martensite involves a transformation from a body-centered cubic structure
to body-centered tetragonal structure. The large increase in volume that
results creates a highly stressed structure. This is why Martensite
has a higher hardness than Austenite for the exact same chemistry…
Photo and Graphs
Credit: Cold Finished Steel Bar Handbook
