Previous in Blog: Scientists Produce Laser Light From Human Kidney Cells   Next in Blog: USB Power Pot Uses Excess Heat to Charge Your Gadgets
4 comments
In Record Drought, Texas Frackers Firefighters And Farmers Compete For Water
Posted June 14, 2011 11:29 AM
From TreeHugger:
Farmers everywhere require water to raise crops or animals. Texas fracking drillers need water - in some counties extraordinary amounts - to extract their product. Fire fighters too need water to douse the flames (as pictured). When there's a serious, extended drought, as there now is in much of Texas, something has got to give. Frackers are offering farmers 40 to 70 cents per barrel of water so they can use that water to extract natural gas and there's no end in sight to the drought.
Re: In Record Drought, Texas Frackers Firefighters And Farmers Compete For Water
06/15/2011 11:38 AM
Comma please. I had to wonder about a Texas Fracker Firefighter.
Good Answers: 7
06/15/2011 1:28 PM
Is it possible for treated waste water to be used for fracking? Or for that mater, firefighting?
It gets interesting when you put fuel and oxygen in the same molecule, without allowing them to react, YET!
06/26/2011 8:49 PM
Possible, yes. There are additional fertilizer elements from this source also, as long as total disslved solids are not excessive, but it may require excessive hauling costs from the water treatment plant.
Just because it has a patent doesn't mean it is the best solution. Just because it has no patent doesn't mean it won't work. A patent is only a license to litigate.
Good Answers: 7
06/27/2011 9:52 AM
This is an example of the free enterprise system at work. Decades ago the auto industry used millions of gallons of potable water to filter air from their painting booths. When they were forced to, they found other ways to do the job, without all that water. The uses you mentioned, are not the same, they still require water, but it doesn't need to be potable. In the long run, the costs of a distribution pipeline for this 'free' water will be less than the ever increasing costs of potable water.
Brave Sir Robin (1); Ethanolics Unanimous (1); Lapin (2)
