Previous in Blog: When Lightning Strikes Out of a Blue Sky   Next in Blog: New Study Links Mountaintop Removal to 60,000 Cases of Cancer in Appalachia
2 comments
MIT Unveils Solar Power System That Doesn't Need Sunlight
Posted July 29, 2011 9:35 AM
From INHABITAT:
A solar energy system that doesn't require sunlight is almost as bizarre as a tidal power system that doesn't use water - however that's exactly what researchers at MIT have cooked up. The team just unveiled a new photovoltaic energy conversion system that can be powered by heat, the sun's rays, a hydrocarbon fuel, or a decaying radioisotope. The button-sized power generator that can also run three times longer than a lithium-ion battery of the same weight. Read the rest of MIT Unveils Solar Power System That Doesn't Need Sunlight Permalink | Add to del.icio.us | digg Post tags: MIT solar Celanovic, MIT solar technology, photovoltaic energy-conversion system, photovoltaic systems, shuttle nasa solar, solar power heat, solar spacecraft
Re: MIT Unveils Solar Power System That Doesn't Need Sunlight
07/30/2011 10:25 AM
Wow! The author discovered, that a photon, other than from light is still a photon, and can do a photon's work. Wow!
Aside that, the discovery speaks of a discovery of diffuse source into a (maybe) single frequency reradiation. Excellent. And efficiency stinks for sure. Now, that is normal for new discoveries, acceptable, except in batteries and energy production.
Aside that, light to electricity conversion efficiency (the basis of all solar panels) is determined by the bandgap of the selected material. Low energy photons do not do anything useful. High energy photons convert to electricity according to the bandgap. Their excess energy is wasted.
Real efficiency exists ONLY at or slightly above the bandgap set photon energies.
Other than that, the article was interesting.
Good Answers: 11
07/31/2011 11:25 AM
hmmm, pretty interesting. The question is how much heat can be generated out of light and how much radiation energy from the sun we get with out the light.
" To infinity and beyond" - Buzz Lightyear
