Speaking of Precision Blog
Previous in Blog: 4 Types of Factors That Can Affect Whether Your Parts Rust   Next in Blog: Pedestal Grinders, OSHA, And You
4 comments
Three Facts About Scale (Iron Oxide) Rust On Steel
Posted August 02, 2011 9:00 AM by Milo
On hot rolled bars to be cold drawn, the dark oxide surface is called scale.
What we see on the surface is "scale" - a combination of oxides of iron.
Scale is the name given to the oxides of iron that are formed on as wrought products as a result of mill operations (high temperature rolling or furnace treatment)
Rust is the commonly used term for iron oxide from weathering or corrosion.
Scale is
  • Hard
  • Brittle
  • High Coefficient of Friction
So we need to get it off the steel if you are to have any chance of keeping the tool edge sharp.
There are 3 oxides of iron:
Hematite ( Fe2 O3) has a microhardness of ~ 1030 D.P.H., is red in color, and is not soluble in acid.
Magnetite (Fe3O4) has a microhardness of ~ 420-500 D.P.H., is black in color, and is not soluble in acid.
Wustite (FeO) has a microhardness of ~ 270 -350 D.P.H., is blueish in color, and is soluble in acid. Wustite is the phase that makes up the innermost scale on the bars or rods.
Hematite and Magnetite make up the outer layers of the scale, and due to their composition, make up the larger mass of scale present. Due to their hardness and quantity they are the real deal-breakers for machining as they create tool edge wear.
One of the ways that Cold Finished Steel bars aid machinability is by removing these hard abrasive oxides from the workpiece, so that they don't destroy your tools and contaminate your cutting fluids.
Bar Coils
Editor's Note: CR4 would like to thank Milo for contributing this blog entry, which originally appeared here.
Good Answers: 266
Re: Three Facts About Scale (Iron Oxide) Rust On Steel
08/02/2011 3:50 PM
Hi Milo,
I know that Magnetite is chemically created to preserve the steel on guns from rust. Are the other oxides used to preserve steel from rusting?
Good Answers: 243
08/02/2011 10:07 PM
Hey there ozzb. Magnetite is indeed the black oxide applied commercially to items such as firearms. Hematite is the rust we are trying to prevent. Milo
08/03/2011 12:30 AM
This sounds like "weathering steel", such as Cor-ten. IIUC, a thin oxide layer prevents deeper oxidation.
Good Answers: 266
08/03/2011 7:45 AM
Thanks Tornado Cor-ten is and example of using one oxide form to retard rusting. Tool black or the applied coating of black oxide another. Any examples of Wustite use?
Register to Reply 4 comments
Milo (1); ozzb (2); Tornado (1)
