It is critical to understand that the selection of free
machining steels goes against the ability of those components to withstand
impact loads.
(Charpy impact values
are reduced by free machining additives and increase with increased
hardenability.)
Impact strength is often an important design consideration
in mechanical components. Cost to manufacture is also an important
consideration in mechanical components.
Free machining grades can reduce the cost to manufacture
precision machined components. But free machining additives reduce the impact
strength of the steel. Materials should be selected on the basis of complying
with design requirements, not just low cost to manufacture.
The low carbon free machining steel grade 1215 exhibits a
particularly low level of toughness over a wide range of temperatures.. Even
light impact loadings are a bad fit for this grade of steel. The principal
effects of the free machining elements (Sulfur and Manganese) added to this
steel are to lower the upper shelf or ductile portion of the absorbed energy
curve.
The effects of hardenability can be seen between the
4140/41L40 and 1141 steels.While the presence of lead in the 41L40 does drop
the upper shelf energy somewhat, the biggest difference can be seen to lie
between the 1141 and the two 4140 grades. The lower hardenability of the 1141
on mill cooling in addition to the effect of the manganese sulfide additives
explains this difference.
The greatest difference however that can be seen from this
figure is the vast difference between the two low carbon steels, Grade 1215 and
1018. Even at 212 degrees F the upper shelf energy of the 1215 is roughly only
a third of that of grade 1018.
Rule of thumb: If a steel grade machines well- it
probably has miserable charpy impact properties.
(Image from The
Assessment of The Mechanical behavior Of Free-Machining Steels, J.T. Berry and
R. Kumar, School of Mechanical Engineering, Georgia Institute of Technology; R.G.Kumble,
Vermont American Corporation. 1975 ASM Mechanical Working and Forming Division,
International Symposium on Machinability.)
Editor's Note: CR4
would like to thank Milo for sharing this blog entry, which originally appeared here.
