Ever get the feeling that bad weather tends to form oh so
"conveniently" around your commute to work? Studies linking air pollution to
weather phenomena indicate that for some regions in the U.S., this trend may
not be all in your head.
The reports have identified weekly cycles in weather
phenomena, including rainfall, lightning, and storms. These cycles describe
what is called the weekend effect, a trend in which these phenomena occur more
frequently on the five day work week of warmer months than on weekends due to
air pollution and emissions. To add to the list, a new study published by the Journal of Geophysical Research says
tornadoes and hail storms follow similar patterns.
Image Source: ThinkStock
The Science
The link between these cycles and air pollution is explained
by heat transfer and changes in temperature. Aerosol particles from pollutants are
a type of condensation nuclei, meaning more cloud droplets form with higher
levels of pollution. Since the moisture in the cloud is spread among more
particles, the droplet size is also smaller. Smaller size means rain develops
higher in the cloud. This height has a direct impact on the severity of weather
conditions.
To begin, condensation at higher heights provides more
potential for clouds to develop into storms. Droplets which reach greater
heights will also form larger rain droplets, and can even form hail if carried
above the freezing line. Large droplets can encourage the formation of tornadoes
because they provide less evaporative cooling during descent, while hail stones
can stimulate the formation of lightning.
The Study
The new study of these patterns for hail and tornadoes was
carried out using statistics and carefully selected data to ensure its accuracy.
Long term trends and seasonal patterns were used to adjust the analyzed
recordings, and only numbers from 1995 and above were used to prevent bias from
advancements in weather-observing equipment.
The analysis was conducted separately for each month and
region of the eastern U.S. It was found that correlation is significant and
relevant only in the southeastern U.S. during the summer months. This is
because warm, moist conditions are required for these effects to manifest.
What does this study mean? Is the U.S. government one step
closer to controlling the weather through labor regulations? Do people in
Florida have work schedules to blame for harsh storms? Perhaps not, but it does
provide some insight into the effect of air pollution on the development of
severe weather.
Source:
Ars
Technica
