How to Select Industrial Products Blog
This is the place for engineers to learn about and teach others how to select industrial products. The blog is maintained by the Editorial team at IEEE GlobalSpec, the company that powers CR4.
Previous in Blog: Selecting DC Motors   Next in Blog: Gearboxes and Gearheads: A Lesson for All
3 comments
Linear Slides and You: A Tutorial
Posted February 09, 2012 12:05 AM by HUSH
The linear slide: the engineering response to DJ Casper's Cha-Cha Slide.
DJ Casper via Communigate | Crossed bearing slide via Isotech
"Slide to the left. Slide to the right. Crisscross. Crisscross. Cha-Cha now ya'll. "
Maybe not so much. Linear slides neither crisscross nor cha-cha. I've also seen an engineer or two "get funky."
However, thanks to this handy little guide, and GlobalSpec's impressive Linear Slide Selection Guide, I firmly believe that asserting your linear slide needs can be as easy as doing the Cha-Cha Slide. (And really, it's super easy. The directions ARE lyrics. Come on, I can't believe this is a song.)
Linear slides are simple linear motion devices composed of a stationary base and a moving carriage. Linear stages are slides with a drive mechanism that provide controlled, precise positioning along a linear axis. Linear slides and linear stages use a linear bearing to reduce friction and guide the slide.
via FDA Bearings
Linear slides typically use a ball screw or lead screw supported by rotary bearings as a drive mechanism to move the carriage. The screw is attached to the fixed base, and the nut assembly is attached to the moving carriage. As the screw rotates, the nut and carriage move linearly along the screw. The screw is turned by a handwheel or electric motor (which may or may not be included with the slide). Alternative drive mechanisms may also be used that do not require a ball screw or lead screw, such as linear motors, pneumatic cylinders and hydraulic cylinders. In a linear motor driven slide, the linear motor directly moves the carriage along the slide. Pneumatic cylinders and hydraulic cylinders may also be used. The cylinder body is attached to the slide base and the cylinder rod is attached to the carriage.
via LM 76
Linear slides can use many different types of bearings to provide smooth and accurate translation. Air bearings, ball bearings, crossed rollers, dovetail or hardened ways, ball bushings, motion guides, needle rollers and sleeve bearings are all common.
When purchasing a linear slide, it's also important to consider axes for which the slide must account. Some slides can operate vertically as well as horizontally. Accuracy can be important for automated assembly processes. Also, drive mechanisms are in important consideration and some slides can be manually driven.
via STAR
There are a few more specifications to consider, but I get the feeling that you really, really want to go over to GlobalSpec's site to check them out. They can offer a better and more in-depth description than what I ever could.
That's not to minimize all the work I've done here. I think I deserve some recognition, actually.
"Everybody clap your hands. Clap clap clap clap your hands. Clap clap clap clap your hands."
Re: Linear Slides and You: A Tutorial
02/09/2012 9:40 AM
Well, Hush, I recognize the fact that your blog writing style is engaging.
It seems to me that you are having some fun with it. Keep it up.
02/09/2012 11:41 AM
Thank you!
HUSH
Engineering Fields - Systems Engineering - New Member Popular Science - Weaponology - New Member
Good Answers: 62
02/09/2012 10:49 PM
And I gotta say, nice to see some out-of-my-field introductory material neatly tied to 'home'.
Well presented without being slapped with a fish.
Kudos!
"If you want to get somewhere else, you must run at least twice as fast as that!"
Doorman (1); edignan (1); HUSH (1)
