How to Select Industrial Products Blog
This is the place for engineers to learn about and teach others how to select industrial products. The blog is maintained by the Editorial team at IEEE GlobalSpec, the company that powers CR4.
Previous in Blog: Selecting [Wire] Strippers   Next in Blog: Picking Out PPE [Infographic]
7 comments
How to Select Toroidal Transformers
Posted November 26, 2012 12:00 AM by Chelsey H
Toroidal transformers are electrical components constructed using a wire-wound, ring-shaped metal core. Ring-shaped circular transformers are known as toroidal because their basic construction involves a toroid, the solid form of a geometric torus. Toroids can informally be described as "donut-shaped." A toroidal transformer's core is first wound with wire to form the primary (input) coil, then overlaid with insulation. The secondary (output) wire is then wound over the insulation. In the image below, (8) represents the primary winding, (4) represents the secondary winding, and (5), (6), and (7) are insulation layers between coils.
A selection of toroidal transformers. Image credit: Allied Electronics
Toroidal transformers feature several advantageous differences when compared to traditionally-built devices:
  • Overlapped coils, as opposed to two separate coils, allow for much smaller devices.
  • Magnetic flux is generally limited to the toroidal core, meaning that toroidal transformers essentially shield themselves from producing electromagnetic interference (EMI).
  • By requiring a smaller number of turns per coil, toroidal transformers feature higher inductance relative to a similarly-sized traditional transformer.
Toroidal transformers also include inherent disadvantages. Because each coil winding must pass through the transformer's center hole automated winding becomes difficult and may necessitate a dedicated winding machine specific to toroidal devices. The unique coil winding also renders toroidal transformers more expensive to manufacture.
The advantages of toroidal transformers are best realized in small, specialized devices and as the size of the transformer increases, the advantages tend to diminish. For this reason, toroidal transformers are best applied to signal applications, such as audio and radio frequency (RF), in sensitive circuits because of the product's miniature
construction and noise-limiting attributes. Toroidal transformers are generally not suited to all but the lowest voltage power applications due to their small size.
Configuration
A transformer's configuration refers to the number of input voltages it can accept, and by extension the number of leads it must include. As the number of leads and required copper wiring increase, the manufacturing and product cost also increase.
A chassis-mounted transformer, connected to a PCB using leads Image credit: Home Theater HiFi
Toroidal transformers are used in medical electronics, test and measurement systems, industrial control panels, data communications, motor controls, light fixtures, audio systems, robotics, UPS, and avionics. For more information about basic transformer operation, power ratings, and standards, please visit the Transformers Selection Guide.
Re: How to Select Toroidal Transformers
11/26/2012 10:47 AM
Just a note:
Not all toroidal transformers have metals cores. At higher frequencies, other materials are used, such as ceramics like ferrite, or an 'air core'.
Also the link at the end seems to be dead.
11/26/2012 2:42 PM
I fixed the link. Thank you for catching that.
“Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.” Albert Einstein
11/26/2012 11:06 PM
Toroidal transformer is like any other, optimised for maximum power transmission. The optimisation comes mostly from the material qualities of the magnetic tape used. The same (better than average) material in different format gives the same advantage.
11/27/2012 12:07 PM
Toroidal transformers are found in the best audio amplifiers. In the real world that is not a lot of power, but if you ever saw one, you would be impressed.
01/01/2013 5:24 AM
The torroidal transformers were found to be good, but not in recent times. The EI is found to be better sounding and the torroid is preffered for high power amps due to its relatively small size.
Gajanan Phadte
03/07/2020 1:29 AM
That a really informative post. It would have been more better if you could have covered based on applications and core size of calculations toroid.
03/13/2020 4:31 AM
In my knowledge here is a piece of detailed information which you would like to know for toroids
https://nicoreindia.com/toroidal-core-characteristics-and-features/
Amulya (2); Chelsey H (1); Envelope Guy (1); gmphadte (1); leveles (1); truth is not a compromise (1)
