E&E Exchange Blog
E&E Exchange
Previous in Blog: Superbugs from the Sky   Next in Blog: Are NGVs the Natural Transportation Alternative?
12 comments
Secondary Organic Aerosols Sold Short
Posted March 07, 2012 9:00 AM by cheme_wordsmithy
For over twenty years it has been known that fine atmospheric particles, most of which are secondary air pollutants, are the most lethal of dispersed air pollutants in the U.S. They have links to both heart and lung disease, and are blamed for the deaths of around 50,000 Americans each year.
If that's not enough of a downer, new research shows that a particular subset known as secondary organic aerosols (SOAs) have a greater total mass than previously estimated, making them even more dangerous.
The Scoop on SOAs
All air pollutants are classified as either primary or secondary. Primary pollutants are those directly released into the atmosphere, such as nitrogen oxides (NOx) sulfuric oxides (SOx) and hydrocarbons which come from different combustion reactions. Primary pollutants can then form into secondary pollutants via interactions in the atmosphere. Examples include the formation of smog from hydrocarbons and other constituents and the generation of acid rain from NOx and SOx.
Secondary organic aerosols are a subset of secondary air pollutants formed from multi-step interactions between volatile organic compounds (VOCs) and other pollutants and chemicals (both natural and manmade). Here's a glimpse of the formation process in diagram form (Image Credit: Dep. Of Atmospheric Science - CSU):
To be clear, while an aerosol is rightly defined as a mixture of gases and particulate matter (PM), most pollutants referred to as aerosols (including SOAs) are just particles.
Just how big are SOAs? Well, aerosol particle diameters can be anywhere from 0.01-100 micrometers (µm) but many SOAs derived from anthropogenic (manmade) pollutants average between 0.1-10 µm.
The size of these particles is what makes them so harmful. In addition to being harder to capture, smaller particles cause more health problems. Tiny particles can travel deep into the lungs, and some can even get into the bloodstream. Smaller particles also cause more reduced visibility, called haze, in parts of the U.S.
(<-- The Great Smoky Mountains seem extra 'smoky' when clouded with haze - Image Credit: Vanderbuilt University)
The New Findings
Secondary pollutants can be more troubling than primary pollutants because they cannot be directly measured. Instead, they must be estimated based on levels of primary emissions and predictions of the interactions that take place in their formation. This also makes it harder to produce sufficient standards to regulate their control.
But a new study by scientists at the University of California and the Pacific Northwest National Laboratory has sorted out some of this confusion on SOAs. Apparently, past studies and models of the atmosphere have underrepresented the abundance of these particles. Actual atmospheric densities could overstep previous predictions by as much as a factor of 10.
Specifically, the new study reevaluates assumptions about the gaseous byproducts from internal-combustion engine pollution. Instead of forming airborne drops which dissipate quickly, these byproducts attach themselves more tightly to airborne organic particles, creating "tiny tar balls" which persist for much longer.
(Perhaps a more legitimate concern for ICE pollution… Credit: The Telegraph -->)
These findings will likely lead to a reassessment of current air pollution control initiatives. Current standards show a lack of emphasis on regulating or controlling VOCs and other organic emissions. This is particularly disconcerting, considering they have a more direct and noticeable effect on the health of people and the environment than the infamous greenhouse gases.
Sources:
NYT - Scientists Find New Dangers in Tiny but Pervasive Particles in Air Pollution
Re: Secondary Organic Aerosols Sold Short
03/07/2012 9:25 AM
Who says?
Was there any mention, in the articles and papers you derived this story from, of concentrations? Which article was the descriptor "tiny tar balls" from?
Technical Fields - Technical Writing - Technical Writer Engineering Fields - Environmental Engineering - New Member
03/07/2012 11:02 AM
Hi Mike. The main New York Times article from which I got this report mentions what you quoted in its first paragraph, and links to a study here where it got its information. I'm not sure on the 50,000 estimate, but the study at the least concludes that this type of pollution increases the risk/rate of death by lung or heart related diseases.
In regards to the concentrations, I don't have any actual numbers since the article mentioned that the study had not been released yet. Apparently it was to be released yesterday, but I haven't been able to find it online anywhere. Here is a link to another article discussing the study from the university itself.
As for the "tiny tar balls", that was another term used in the Times article (fourth paragraph from the bottom).
Hope that helps.
“A man wrapped up in himself makes a very small bundle.” — Benjamin Franklin
03/08/2012 12:02 AM
Why do they call the Smokey Mountains, "smokey"? Are you aware of the number of natural pollutants that we affected by? The number of wildfires each year, across the Globe- The amount of natural oil and petrocarbon seepage each year, -The number of Volcanos erupting, sending the same pollutants into the atmosphere, at varying altitudes--VOG, on the Island of Hawaii,is directly related to Kilauea Vocano , having erupted for over 16 years straight (Do a little research)--There are subterranean Volcanoes erupting right now, off the coast of Greenland, Hawaii, and Indonesian hotspots, that are releasing pollutants, either into the atmosphere , or into the sea water. Mt. Pinabuto, Mt. St. Helens--Research the amounts of sulfuric acid etc, shot straight into the atmosphere--That doesn't mitigate Man's contribution, but what are you going to do--Sue God? We are a living breathing Biosphere, and the rest of the planets around us are a lot worse off, and not due to internal combustion engines--Sounds like someone looking for a little research, or grant money--Lots of that around--Sorry to be cynical, and if not true, then call me on it--
03/08/2012 8:52 AM
No, I agree. I was just using the smoky mountains as an example of haze: naturally caused or not, it shows what this type of air pollution can do. Photochemical smog in urban areas is a different (more anthropogenic) example.
And you're right, the biggest impacts on our environment (based on current predictions) are natural sources, even for SOA formation [3rd slide in this pdf provides some info on this]. However, that's not to say that in urban areas (where there are larger concentrations of anthropogenic emissions) we shouldn't be concerned. To me, the important thing is not pollution as it relates on a global scale (of manmade vs. natural/climate change/what-have-you), but pollution as it relates to breathing clean air in the places we live (both indoor and outdoor, urban and rural). For example: volcanoes may be a natural source of pollution which the earth's atmosphere has handled since its inception, but that doesn't mean I'd be happy to breathe the air around the affected area after it erupts!
Having an accurate understanding of SOA formation and growth is part of being better informed of what's out there and where it's coming from, whether we're causing it or not. Sure, they might have an agenda, but the research itself is still important if its findings are true.
Good Answers: 119
03/08/2012 9:05 AM
Not a criticism, just an observation...
The Smokey's and the Blue Ridge (where I live) were called that long before there was any significant man made pollution in the US.
That said, welcome to planet Earth where no one gets out alive. Just some of us make it longer than others.
Hooker
03/08/2012 10:56 PM
03/09/2012 3:58 AM
And the Natives who lived in what today is called the Los Angeles Basin, where I grew up, called that place the Valley of Smoke due to the persistant inversion layer keeping the smoke from their home fires down low - anthropogenic or not, pollution is here to stay and we will always need better ways of managing the situation.
03/09/2012 4:31 AM
I had some notations I wanted to make about the OP.
VOC both natural and/or man made are never constant. i.e natural VOC output is down drastically in the northern Hemisphere from late fall to early summer almost none in mid winter (that is if the winter is cold enough). then steadily rises from spring to reach its highest output in mid or hot summer (July-Sept), then steadily lowers until mid winter or cold winter (Jan-Mar). This VOC is not all that happens at this same time. Forested areas in the Northern Hemisphere from spring to fall have decomposition that is on going as well as any natural VOC it produces a higher CO2 output as well. Not all materials being decomposed are VOC compounds. Not to mention the bacterial output into the atmosphere also anther study altogether.
Having said all that we know that the Solar activity over the last 15 years has been decreasing and at the same time we saw larger amounts of sunspot activity and high earth temperatures. so the 15 years have seen an increase of natural VOC activity and CO2 output as well.
Interesting as the illustrations were that is not the only Chemical and atmospheric activity going on daily. i.e. example daily water evaporation (with or without pollutants) H2O is taken into the atmosphere some cools quickly and returns or stays at lower altitudes. some goes higher, when it is exposed to the high level UV rays from the sun the water is converted to Ozone O3, when the O3 is cools along its lover altitudes some of it then breaks down to H2O2 and H2O. All of which make up the atmosphere.
So when you see charts diagramming the VOC, man made hydrocarbons, NOx and SOx, and its secondary outputs you must also consider the natural processes or the natural multi-step interaction of the whole thermaldynamic system that our planet and its atmosphere are and that is going on at the same time. Some of these help reduce pollutions and some add to it but the earth in and of it self has a way of coping via its thermaldynamic system. Many of the climate scientist completely forget all the other factors when trying to show that Global Warming is caused solely by man made products but that is not an absolute truth it is only a partial truth. And they forget to show how the earth in and of itself copes with this naturally.
Remember there is anthro-pogenic and natral-pogenic (natural i.e. volcanic sulfurs, nitrogen oxides and hydrocarbons just to show a few) pollutants and the thermaldynamic system is for some reason really helping in maintaining the atmospheric pollutants. To better understand the underlying thermaldynamic system of the Earth will help scientist to better understand our planets coping mechanics. Truly the odds of this type of thermaldynamic system that is unique to the earth happening in another solar system or galaxy is incalculable. and so far has not been discovered.
03/09/2012 10:26 AM
Good thread , with some very common sense comments, and excellent "data". I remember a few years back, Scientists in an Indian University were confused by high micro-particulate levels in the Southern Hemisphere. THey did not seem to adhere to the patterns mentioned in the previous comment. As it turns out, the particles being registered were the result of charcoal fires, used for cooking, by many of the countries in the Southern HEmisphere (India, Java, China, Africa, etc.)--An classic example of localized pollution going somewhat Global. But, they noted, that that type of particulate was quickly washed out of the system due to its fairly low level altitude. On the other hand,the particles emitted by Karakatoa , in the 1800's travelled in the upper atmosphere, around the planet for over 6 months. More sulfuric acid was emitted by the "short" eruptions of Mt. St. Helens, and Mt. Pinabuto, than the total of man's emissions since the Industrial Revolution. Here, in Los Angeles, I watched a news helicopter live footage catch a 6.0 Northridge earthquake aftershock as it moved across a series of ridges--The amount of dust lifted was amazing, similar to watching a stream of machine gun fire trails--It gave me a whole new viewpoint of "emissions"..
03/09/2012 11:17 AM
I think it is so interesting that you write "dispersed air pollutants in the U.S." What about India, Russia, and the biggest offender China. If you want to save the world from these terrible pollutants stop buying stuff made in those three countries. If we, in the U.S. were to be able to reduce our secondary organic aerosols to zero we would not be able to help the world that much. There is so much in the atmosphere that comes via the jet stream from the countries west of us that what we need to do is make stuff here where at least we care about our environment. "Nothing from China" If you think that stuff is no longer being made here, then when you go to your search engine, type in the following "Made in U.S.A." + (your product choice) you may be amazed by how much stuff is still made here. Also, the production workers here are contributing to the tax base, not taking from it.
A hand without an arm is a useless tool
03/09/2012 9:41 PM
I found the original study published under the national inst of health and the Library of medicine to be skewed at best but more than likely manufactured.
They did a study on a specific 4 days (their choice of days) and attributed to air pollution an increase in deaths over that four day period of time attributing it to an increase from 1999to2005 while publishing their results in 2009. Also they are showing a showing an undated map of mortality that is linked to summer months but stating that the increase was in spring. so the summer mortality map and their spring stats don't match making this a suspicious study that more than likely had a political motive behind it.
Why are they placing a summer map with Spring stats? possibly the spring map didn't correspond to their desired results. Also the doctors linked to statistic sheets that had little to do with particualr pollutions and more to do with mortality rate in Humans that may not be connected to the results they arrived at in their conclusions. Was there a real peer review or were they just allowed to publish this to the US Library of Med and US Institute of health with no one checking their work?
A sixth grade science class could have produced a better study, as they in no way could or did connect any of the increase of mortality by stroke, heart attack or respiratory ailments solely to man made air pollution.
The study is biased and as far as I can tell manufactured by the authors of the article. A study like this could not be done over a four day period of time. to get conclusive results this study would have to be done over a minimum of five years and then they would also have to have conclusive results of corresponding studies of Air quality, vehicular emission and count stats (vehicles driven each day), production plant emissions, then other studies like bacterial levels, fungus and mold spore as well as pollen counts (which is higher in spring) (none of which were sited in the original study so it could be verified.
Based on their stats and studies they site I could claim that the mortality increase was caused by a combination of mold, fungus, pollen increases and natural VOC level increase than to claim chemical, plastics manufacturing, auto and other man made pollution. and all I would have to do is add a charts of the pollen, mold/fungus spore counts for the same years.
Possibly they just threw this report together to justify what they did with the funds that were granted from the US Government for their study (probably into the the hundreds of thousands of dollars). This reminds me of the "hide the decline" work done by the supposed experts of global warming now termed climate change. And now the true results of glacier and and polar ice cap melting showing that there has been very little decrease of either.
I would have to research their study and the work they would of had to site in order to come up with their claims. But from I read they did a poor job.
03/10/2012 11:52 AM
It is good to see that some of us don't accept for scientific fact articles published by the New York Liberal Times. Can anyone say agenda?
Keep up the good work.
Byron Jay (2); C-Mac (2); cheme_wordsmithy (2); DocCKR (1); Hooker (1); MacNichols (2); Mikerho (1); SWB123 (1)
