E&E Exchange Blog
E&E Exchange
Previous in Blog: Ultracapacitors - the Batteries of the Future?   Next in Blog: Does Nuclear Power Have a Fading Future?
11 comments
Liquid-Like Thermoelectrics
Posted March 28, 2012 9:30 AM by cheme_wordsmithy
About two months ago I reported on research being done to make thermoelectric materials using a standard microwave oven and some innovative nanotechnology. The process, developed by RPI, aims to make thermoelectric devices both more affordable and more effective. But new research from the California Institute of Technology provides another possible solution: a new liquid-like compound with a higher conversion efficiency.
Thermoelectrics: A Brief Summary
If you're unfamiliar with thermoelectrics, they are devices that can create electricity from a difference in temperature or create a temperature difference using electricity.. This is accomplished by creating a system in which the movement of charge carriers from one side to another is induced by a temperature gradient between these sides (or vice versa where charge induces temperature changes), called the thermoelectric effect.
Thermoelectrics currently have a niche in refrigeration where reliability and system life are more important than cost or efficiency. They are also used in cars to convert waste heat to electricity. They have the potential to make any process that involves waste heat more efficient, but the low conversion rates and high material prices don't usually provide a positive ROI.
Making Thermoelectrics Better
Effective thermoelectric materials must have high electrical conductivity but low thermal conductivity. Good electrical conduction means electrons can flow easily through the material with little resistance. Poor heat conduction is needed to prevent the material from quickly reaching thermal equilibrium - once the two sides are the same temperature, the electrons stop flowing.
To make thermoelectrics more effective, researchers have been looking to combine properties of amorphous and crystalline structures to develop a material with the most ideal thermoelectric properties. In solids, heat is transferred through vibrations both longitudinally and laterally. In liquids, these vibrations only travel via longitudinal waves. Because of this, a liquid-like material that is also good at conducting electricity should be more efficient than traditional amorphous materials.
Caltech's study was on copper-selenium material, which exhibited these combined characteristics. Although it is physically a solid, the flow of its copper atoms through the crystal lattice gives it liquid-like behavior. The team found that the crystal structure of the selenium provided better electricity conduction while the heat transfer was dampened by free flowing copper atoms. Copper-selenium was actually used in spacecraft design by NASA around 40 years ago, but its unique properties were not understood at that time.
Opening a New Door
While copper-selenium may be more efficient, it's likely to be difficult to produce on a large scale because of its liquid-like nature. The importance of this research is that it provides scientists a new approach to finding other, more viable thermoelectric materials that exhibit similar qualities.
I'm always excited to hear about developments in this technology - there are so many possibilities that stem from thermoelectric development. Thermoelectrics in refrigeration could cut the costs of commercial and industrial cooling systems and replace the types of coolers we use today involving compressors and refrigerants (more moving parts). In addition, any technology/process that generates waste heat, (be it combustion engines or incinerators) could potentially benefit from the integration of thermoelectrics into the system. Nifty little gadgets that harness untapped sources of heat energy, such as human body heat, are another outcome of progress in thermoelectrics. I mean, who wouldn't want a cellphone that could be charged just by holding it?
Sources:
Caltech News
Thermoelectrics - Caltech Materials Science
Wake Forest University - Power Felt Gives a Charge
Re: Liquid-Like Thermoelectrics
03/28/2012 10:07 AM
The research being done on improving the efficiency of Solar energy is much more exciting....imo
"The process, called "photon enhanced thermionic emission," or PETE, could reduce the costs of solar energy production enough for it to compete with oil as an energy source."
"Melosh calculates the PETE process can get to 50 percent efficiency or more under solar concentration, but if combined with a thermal conversion cycle, could reach 55 or even 60 percent - almost triple the efficiency of existing systems."
"A small PETE device made with cesium-coated gallium nitride glows while being tested inside an ultra-high vacuum chamber. The tests proved that the process simultaneously converted light and heat energy into electrical current."
http://news.stanford.edu/news/2010/august/new-solar-method-080210.html
03/29/2012 8:58 AM
I am just wondreing whther this Thermoelectric technology could be used for heat application using 12 V D.C power generated by a Solar photovoltaic panels. Conventional resistance heaters draw heavy currents at this low voltage, and using of inverters for increasing the voltage is a costly and also a wasteful process. Could you help me ?
03/29/2012 12:34 PM
Electricity for resistance heat is the least efficient method of obtaining heating....If you have solar thermal panels, using panels to heat exchange fluid, this is much more effective and efficient....
03/29/2012 7:54 PM
Agreed that heat exchange thermo panels would be ideal. Present solar water heaters used in India (Especially in Bengaluru) are of that type. But the solar cookers (Non-concentrating type) can at best cook Riace, and they need visits in the hot sun for re-orienting the cooker towards the sun every 10/15 minutes. Solar PV panels on the other hand may not be very efficient, but the cooking could be done in side the cool kitchen. That is the reason I was interested in liquid like thermo electrics.
03/30/2012 3:55 AM
Propane cooker would be much cheaper..pv would be several thousand dollars...
03/30/2012 4:29 AM
Whether we use Propane or electricity generated in the usual way (Conventional), we are not using a renewable source. Solar, being renewable, is an ideal source. Economical or not, one day every one of us as to resort to use of solar energy in daily life, andthe question of mine is in that context.
03/30/2012 8:41 PM
Then my choice would be ethanol, which is a clean non-polluting renewable resource and can be easily manufactured on a small scale...
http://www.projectgaia.com/
http://climatetechwiki.org/technology/cook_ethanol
03/30/2012 10:38 PM
Ehanol, like any hydrocarbon fuel, produces carbon dioxide as one of the end products. With solar energy, whether photoelectric or thermal, there are no end products that would cause ecological problems. Hence, the need of the hour is to have a direct conversion of solar energy to electrical or atleast a convenient way to use it for our day to day operations like cooking, cooling, heating, mobility etc.
03/30/2012 10:52 PM
I don't agree, ethanol produced from biomass and/or food waste is carbon neutral...and in fact by using biomass and/or food waste that would otherwise be left to degrade naturally producing methane gas, a greenhouse gas 30 times more potent than CO², you are actually carbon negative in total effect...that makes it better than solar...
04/01/2012 10:13 AM
Sunlight is the source of most of the energy on Earth.
Propane (derived from oil) is ancient sunlight, biomass/ethanol is young sunlight and solar systems are fresh sunlight. Carbon from oil has been sequestered for thousands of years and is being returned to the atmosphere at an alarming rate. We need better sources of young and fresh sunlight to produce energy without releasing all that sequestered carbon.
I hope thermoelectrics become more efficient at cooling than generating electricity. We have many sources of heating and generating electricity from fresh or young sunlight, what we need is cooling.
Drew K
04/01/2012 6:19 PM
I think Drew K has put the matter of sunlight in the right perspective by refering to the 'Age' of sunlight. Yes the need of the hour is to use the young sunlight directly.
The problem of efficiency, according to me is secondary. It is the storage that is the big bug. Electrical energy per se, has the shortest shelf life. Unless it is converted to other forms, such as chemical, thermal, static or whatever, production loses its sheen. The solution would be to continuously produce electricity from Sun, and convert it to static energy, by using a pump to pump water to a height, and use that water at will, to produce back electricity.
In this quest, liquid like thermoelectrics would be helpful
Drew K (1); Gadepalli Subrahmanyam (5); SolarEagle (5)
