Previous in Blog: Flexible Hones for Firearms - Instructional Video   Next in Blog: Flexible Honing for the Kawasaki ZRX1200
Flexible Honing for Paintball Guns
Posted June 19, 2012 8:29 AM by Brush Research
Paintball is an extreme sport in which players "tag" their opponents with soft-shelled capsules filled with paint or dye. When fired from a paintball gun (marker), these capsules (paintballs) explode upon contact and mark whatever the shooter hits. Founded approximately 30 years ago, paintballing continues to grow in popularity as equipment manufacturers develop better paintball guns, ammunition, and tactical gear. Today, shooters can choose from burst, pump action, automatic, and semi-automatic markers. Powered by compressed gas, paintball guns are like other firearms in that they require cleaning and maintenance. Fortunately, the flexible hones for firearms provide a superior surface finishing solution.
Flexible Honing for Paintball Pistols
To get the most from their markers, shooters like the contributors at M. Carter Brown, an on-line forum for paintballing, use the Flex-Hone tool from Brush Research Manufacturing (BRM). In a thread called "How to Get the Most from Your Newly Honed Pistol", owners of Redux and Armotech Zeus paintball pistols recently discussed the value of flexible honing. CJOttawa, a Canadian user whose tagline is "immune to sales tactics", described his plans to "hit the Redux barrel" with an 800-grit aluminum oxide Flex-Hone. Rob from Michigan added that finishing the barrels of his Zeus paintball pistols with the Flex-Hone for paintball guns provided greater accuracy at long range.
Rear Bore and Barrel Hones
Built with a stiff, coated stem and finger-like formations of abrasive globules, the Flex-Hone for Firearms follows the geometry of the bore to polish the metal gently and create a uniform surface finish. For paintball pistols, choose either a rear bore hone or a barrel hone. Both are designed for .68 caliber paintball guns, but Brush Research can also design custom tools. The rear bore Flex-Hone uses aluminum oxide (AO) abrasive and is available in 600 and 800-grit. The barrel hone offers a choice of aluminum oxide (AO), levigated alumina (LG), or silicon carbide (SC) abrasives, and is available in either 600 or 800-grit.
For more information, watch our new Flex-Hone for Firearms video and visit our website, where you can read more about flexible honing for firearms.
Author's Note: This CR4 blog entry originally appeared in BRM's Flex-Hone Blog.
